Large format rectified polished porcelain with no Grout in a shower?
What size tiles .
How thin.
What are shower dimensions .
Conventional wisdom is to grout joints between tiles . But you may be saying large panels that only need siliconing in the corner and at the floor as there may be no other joints
Yeah it would depend on the size.
Large tiles are hard to get coverage on. And it's not for the faint hearted. Have you tiled before? What background are you tiling onto? Have you considered how you're going to waterproof the shower area before you fix a tile? The tiles wont waterproof the shower alone. You need to 'tank' the shower before you even mix your tile adhesive etc.
They have to be grouted between the tiles and siliconed in the corner . Waterproofing your shower area before tiling is good practice although I don't know if it's a tcna recommendation or not . Maybe something you should check
It's an older home, that had 5/8 plywood with old school Melamine panels glued to it. I was going to screw cement board right over everything, tape and seal the joints and corners
In tile setting terms, we've only been in metric for a couple of decades and our average member age is 50. So we've got thousands who still haven't converted to metric on here lol 😀 😀 😀
They also want it vertical so I am also worried about how flat the walls will turn out. I'm just their caretaker and want to advise them to get a pro but everyone is so busy, no one returns calls in our extremely rural area. Also, the home is shut down in winter, I mean all heat will be off.
Cement board generally tends to be water tolerant no waterproof. Although your products maybe different
craigy,
craigy,
craigy,
craigy,
