Minnie
the pics are fine Minnie, no probs with you posting themYou want to be getting an acrylic primer,don't let them fob you off with PVA
Oh, I've read about the nastiness that is PVA from you lot so I was determined not to get that.
However, I forgot to ask. Better go and check to see what I ended up with.
hm, can't see. It's "Mapei Primer G - synthetic resin-based primer in water dispersion with very low emission of volatile organic compounds, for cementitious adhesives and smoothing compounds on pourous, non-porous and gypsum-based substrates"
PS: I know all you professional tilers advocate mixing your own adhesive but I figured for a novice (and it was suggested by Tile Magic) that I use the ready-mix stuff, so I've got a blue tub of the Mapei adhesive. Will that work with this Primer G?
