Marmox board
Ollie02948
I have installed marmox board onto a solid wall. Also there a plastic plugs and nails supplied. Was wondering what th drill diameter is for the plugs?
Never seen them, but buy a 6mm drill at a guess, test drill a hole in a brick and see how it fits. It should be tight enough so you have to lightly hammer it home. If the hole is too tight the plug will bend and you will need a drill 1mm bigger.
Marmox board
Ollie02948,
micko,
Ollie02948,
micko,
