Discuss Montolit in the UK Tiling Forum area at TilersForums.com.
MTiler
I have that cutter too and its brilliant, especially on mosaics! I havent tried it with a mosaic mat though which i understand makes it even better.
I think the best bit of it is the weight and the ease of use when doing 45 cuts as the measure scale is easy to use. It takes a little while to get used to how to adjust the wheel pressure and not being able to see your cut line as its single rail but i cracked that in about an hour of using it
I initially bought the 43 for mosaics, its brill, Ive never got around to getting a mosaic mat, I use some card!
missyT
Reply to Montolit in the UK Tiling Forum area at TilersForums.com
Evening all, So getting back into the swing of it all again and need to get myself a new wet...
11K
Gonzo1969
You can find DNA blades for Tile Cutters at a very reasonable price from ************** 180mm...
14K
hmtiling
H
Got a job coming up with 600 x 600 polished porcelain - current Rubi cutter only goes to 500 so...
5K
I am currently doing a new build where the customer has bought some tiles from Porcelenasa...
28K
Italy
I
Hi all, I'd really appreciate your guidance if any of you would be so kind. Apologies in...
7K
Montolit
