Discuss My first job in the British & UK Tiling Forum area at TilersForums.com.
macten
1,158
Nottingham
I'm starting to detest this bathroom!
Finished the wall tiling today (good news is the new batch of tiles match in colour)
Still got the 75mm skirting in the floor tile to fix tommorrow - all cut and ready though.
Fitted and plumbed basin only to find that the pedestal is lop-sided so now need to grind one corner down.
I've measured each side of this cheapass pedestal and it's over 1/2cm out. Need to lay my hands on an angle grinder - spent ages filing it today and only managed to take a couple of mm off.
Oh and they've gone an bought a new shower - pipe intake and wiring totally different to what I've allowed for. Looks like I may have to remove that tile and cut a new one - me weeps
macten
1,158
Nottingham
One stroke of luck tonight. My brothers' neighbours airing cupboard sprung a leak - circ pump isolation valve. Picked up a pair of valves from plumbers merchant, only 5 quid.
Drained down her system (took an hour), fitted new valves and refilled. One rad wouldn't get hot (airlock) sorted that and walked away with £125 and was fed a chicken curry. Result
Basin finally plumbed:
Framework for bath panel:
Shower is finally installed. Made them change it for another model that had left hand entry for wires. Didn't need to remove tile, the shower control box now fits close to the wall so the shower hose/head is now central.
Got to finish last bit of skirting (2 pieces).
Grout floor
Tile bath panel (+ sort access)
Silicon
Can anyone give me advice for the correct use of a washboy - one for dummies please.
sWe
One washboy tutorial coming up:
Fill the washboy with cold, clean water, so that it covers the grating by around 2-3 cm.
1. Wet/clean the sponge. If the float is dirty, you'll remove the "muck" by pressing against the grating.
2. Remove the excess water. Do this by going over the rollers with the sponge float once, then stopping with one end "flat" against the roller, and then "squeese" the end down on the roller, tilting the float to an angle of about 45 degrees. Repeat on the other end, and go over the rollers with the entire float again. If the sponge leaks water when going over the roller the last time, you need to repeat. You want the sponge float to be as clean as possible, and damp, not wet. To much water can damage the grouting mortar, making it brittle and unevenly coloured.
How to use the sponge float (my prefered technique):
Only grout and clean one surface at a time, and if it is large, you may want to divide it into sections. Doing this ensures the grout doesn't dry up to much. Bear in mind that you don't want the grout to be too fresh/wet either. If it is too wet, the additional water on the sponge will weaken the grout. You have to find a compromise between ease of cleaning, and the amount of time you wait before cleaning, up to a certain point. Wait to long after application and the job will be botched. Wait to little, and the grout will crumble after a few months.
Always begin from the top, or you'll have to go over the entire thing again just to clean away drippage.
1. Go over the tiles in a circular motion with the sponge float. Your objective in this stage isn't cleaning, but to even out the grout.
The circular motion also cleans away the worst excess, but leaves enough to work with when cleaning. Clean the sponge as needed, but not too often. Fill out any gaps in the grouting as needed. Often, you just need to use a finger.
2. When the grout is fairly even, you can start removing the excess grout. Do this by pressing the float firmly against the surface, and going slooowly in a horisontal motion. Start from the top. Clean just as you start noting the float leaving as "track".
Any dirty excess water drips downwards, and by keeping the motion horisontal, you clean the drip up as you go.
If there is a "film" on the tiles, wait a few minutes for the grout to become a little bit dryer to the touch, and go over the surface lightly with the float. Make sure it is just damp with clean water. To much water may weaken the grout; dirty water is counterproductive.
Cleaning grout is about finding a good compromise between speed and the quality of the result, which works for you and your way of working. Some techniques require loads of time, but produce perfect results, and vice versa.
I find that my technique is sufficiently fast for the most part, and the result is as close to perfect I can get within a reasonable amount of time.
When you're done grouting, empty the water somewhere you don't risk causing a blockage. In the bottom of the washboy, there will be a layer of cement. If it's new, it'll be lose, and you can scrape it out, or wash it out with a hose. If it's been there for a day or so, or if you've been doing lots of grouting, then you can "tap" it out, by putting the washboy upside down, and tapping with the handle of a trowel round the edges. Do not tap in the middle, as you might crack the plastic if you tap too hard.
I might add a few things later.
Cheers.
EDIT: Updated with a few clarifications
macten
1,158
Nottingham
Thankyou very much sWe.
When I am evening out the grout and you say go slowly horizontally - Shouldn't I be following the grout lines which are horizontal and vertical. Apologies if I'm being thick but I haven't finished my course yet and haven't done floor tiling yet.
sWe
Well, the purpose of that would be to smooth out the grout, but you do that with the circular motion. The circular motion also cleans away the worst excess, but leaves enough to work with when cleaning. The purpose of the horisontal motion is to clean away the excess smudge left on the tiles after you gone over with the circular motion once.
Also, any dirty water drips downwards, and by keeping the motion horisontal, you clean the drip up as you go.
This is what I prefer. If you experiment a bit, you might find something which works better for you.
Final notes: Only grout and clean one surface at a time, and if it is large, you may want to divide it into sections. Doing this ensures the grout doesn't dry up to much. Bear in mind that you don't want the grout to be too fresh/wet either. If it is too wet, the additional water on the sponge will weaken the grout. You have to find a compromise between ease of cleaning, and the amount of time you wait before cleaning, up to a certain point. Wait to long after application and the job will be botched. Wait to little, and the grout will crumble after a few months.
brian c
Nice job, put some pic's on when you have finished.
Just for intrest how much do you think it would have cost if it was a paying job ?
Anybody....:joker:
if you were getting a bathroom firm in you would be looking at 5 to 6 grand.
Well done macten you have done a fantastic job there m8,keep up the good work and your high standards...and im positive you wont be short of work:thumbsup:
F
faithhealer
I would price the job at about 3,500/4 grand inc mats except tiles. Most impressed with, of all things, your bath panel frame!! That ain't going to move. Good luck with the rest of the project. One tip if it's for a customer, VERY IMPORTANT, get half the money up front, at least one week in advance to clear cheque! it's a lot to lose if you have a dodgy customer.
macten
1,158
Nottingham
Not much progress, I can feel myself lose motivation, must remember I'm on the home stretch. I get more encouragement from you guys than I do from the new owners of this bathroom. So thanks, it's greatly appreciated.
Shower in:
Skirting tiles in and floor grouted:
Having tommorow off (well kitchen fitting with my dad actually) but I recon flatpack assembly will be a damn sight simpler than this has been.
Shall we have a sweepstake to see who guesses closest to the nearest pound how much I will eventually get for this job.
I'm guessing sweet FA bar my materials costs :disappointed:
bishbosh77
Great job, if you dont get payed there loss as you wont be doing anymore jobs for them. Look on the bright side it will be a great start for your portfolio, at the mo im doing an NVQ plumbing course and if i can do a full bathroom job as good as you i will be well pleased, keep up the good work.
:joker:
Reply to My first job in the British & UK Tiling Forum area at TilersForums.com
  • Question
Hi guys, I'm currently on my first job after finishing the 9 day course with UK Pro Tiling...
24K
James De
Hi all, I've just had 4m2 of white bevelled metro tiles done in my kitchen by a guy who...
23K
Hi guys, its my first post on there though have been gaining useful tips for a while so thanks...
hi there, i was not sure if i should put this in find a tiler section as i was more hoping the...
Unused Account 1
U
macten
Nottingham
My first job
    Votes: 9 5.3%
    Votes: 17 10.1%
    Votes: 12 7.1%
    Votes: 48 28.4%
    Votes: 21 12.4%
    Votes: 40 23.7%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 23 13.6%
    Votes: 19 11.2%
    Votes: 17 10.1%
    Votes: 8 4.7%
    Votes: 5 3.0%
