Discuss My first job in the British & UK Tiling Forum area at TilersForums.com.
macten
1,158
Nottingham
Quick question guys. I have been doing the majority of the cuts on my wetsaw (24'' QEP Bridgesaw). Works a dream on the wall tiles but I have noticed that it had difficulty keeping a pefect line when cutting full tile on the floor tiles. It's as if the tile is pulling the blade 2-3mm to one side and has consequently eaten into the aluminium bed a little. This also, more often than not, caused the corner of the biscuit to break a little at the end of the cut.
I think the floor tiles are a glazed porcelain (porcellanato) but I would have thought the 200mm continuous diamond edge wheel should still have coped. It obviously doesn't so was wondering what wheel you guys would recommend - something I can rely on to cut owt I throw at it.
The arbor is 22.2mm.
sWe
You can cut porcelain and porcellanato with a dry cutter, if you have one. Porcellanato eats scoring wheels though, so it pays to have one specifically for porcellanato.
As for the blade not keeping in line (wobbling?): The blade is most likely not optimised for what you're using it for. It's probably meant for softer ceramics, not the real hard stuff. You likely need a blade with a reinforced core. If that's not the problem, then it might be that your wet saw is not producing enough torque.
As for the "corner of the biscuit to break a little at the end of the cut"; flip the tile and try pre cutting a few centimeters, and then flip it back. That usually remedies the problem, as the stress on the tile gets a more even distribution.
macten
1,158
Nottingham
Thanks for that sWe.
The blade shows no sign of wobble it is just getting pulled off line with these floor tiles. So worried that the flipping idea might not work as it's doubtful that the 2 cuts will meet.
The motor is 900W and shows no sign of slowing down or change in sound and seems very powerful (it cuts the tile with ease) so not sure torques the problem.
Whats the difference between porcelain and porcellanato?
macten
1,158
Nottingham
Thank God I've FINISHED!!
Thanks for all the ideas and support guys.
Placing the last tile:
Grouted up and room siliconed:
Access panel:
Lopsided basin pedestal finally made straight:
Makes me laugh and cry when I see this:
cameo
I read somewhere on the site about the construction industry failing to provide honest tradesmen and the fact that there are people worried about the amount of seekers and cowboys in the trades. After nearly ten years in roofing following an accident im retraining to become a tiler and i too was worried about the amount of cowboys etc but i must admit, after reading through loads of posts and threads i couldnt be more wrong. Im glad i joined up to this site and witnessed what good spirited people you all are. i wish there was a site like this for roofers when i was roofing cause ive seen work that would make a cowboy look good:8: :yes: :thumbsup:
billy123
may i be really honest with you? looking at your pics tells me you will be fine in the long run,however,your family are p****ng up and down your leg. learn from it and in future price family work under mates rates.that way if you dont want it let them go elsewhere. but youwill be ok somenice work there well done!!
Reply to My first job in the British & UK Tiling Forum area at TilersForums.com
  • Question
Hi guys, I'm currently on my first job after finishing the 9 day course with UK Pro Tiling...
24K
James De
Hi all, I've just had 4m2 of white bevelled metro tiles done in my kitchen by a guy who...
23K
Hi guys, its my first post on there though have been gaining useful tips for a while so thanks...
hi there, i was not sure if i should put this in find a tiler section as i was more hoping the...
Unused Account 1
U
macten
Nottingham
My first job
    Votes: 9 5.3%
    Votes: 17 10.1%
    Votes: 12 7.1%
    Votes: 48 28.4%
    Votes: 21 12.4%
    Votes: 40 23.7%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 23 13.6%
    Votes: 19 11.2%
    Votes: 17 10.1%
    Votes: 8 4.7%
    Votes: 5 3.0%
