Never used a grinder to cut tiles...
I just find it easier on little wet saw, some times end up with small cuts under units etc to do
I can it's just that over here sometimes you come across problems like where sparks can't keep sockets at the same hieght for some reason 😉 awkward stuff like that where you may need a 5mm piece left on a check etc, horrible situations 😕
I've read with interest and i'm not convinced, I still dont understand why you'd want to do it, you've got a higher risk of injury with grinder kicking back, chips in your eyes, dust in lungs.
Don't get me wrong Ive got two grinders but unless with were huge format tiles i'd just use a wet cutter
Theres things called safety glasses/goggles and masks, plus I use a grout float to hold stuff down where possible.
We all have our own ways of doing things thats suits any given situation.
Half way through a 15month project and the main contractor tells us we all need kick back stop grinders. We had 20+ tilers on site so obviously a huge cost. We fought it and won because
1. Kick back when cutting 10mm thick tile rarely happens. You're doing something wrong if it does. Safe operating will prevent it.
2. Kick back grinders (at this time) only started at 125mm. So we'd have to go for larger more powerful grinders in order to get the needed safety feature.
We do wear dust masks when operating. Glasses should be worn with wet saw aswell.
A nice dewalt wet cutter would be a nice replacement for a grinder but come at a huge cost for larger companies.
You could get them a Dewalt but they wouldn't look after it!
Health and safety is a must. Insist on goggles and ear muffs or your insurance could be void.
20 + Tilers - what did you do in a previous life to deserve that.😉
Another plus one for the grinder. A grinder in the right hands will leave a great finish. I always wear Google and a dust mask. Always do my cuts outside. Grinder only kicks back if you are not cutting straight.
I've just bought a Bosch GWS 7-115e and it gets quite hot at slow speeds and doesn't sound the best anyone else have the same problem I don't know if that's what they are like or should I send it back I have the flex variable speed and it's a lot smoother
I confirm, at low speed, it becomes warm.
It happens to me, when I use it on screeds.
