Discuss ***NEW HARDIEBACKER VIDEOS ON TILERS FORUM*** in the Canada Tile Advice area at TilersForums.com.
We now have several videos demonstrating installation, cutting techniques and tips which I am in the process of uploading on this forum.
Both our 6mm and 12mm boards are very strong and durable. Sometimes we hear they are difficult to cut. This is normally due to using a utility knife. As the board is 90% Portland cement and sand you will always struggle!
The videos demonstrate using our score and snap knife. This way all cuts can be done inside the bathroom or kitchen. I demonstrate half board cuts, small strips, even corner notches.
If there is anything further you wish me to show you please feel free to ask. Of course a power tool will be the quickest way for any awkward cuts. We just recommend you use any power tool outside, down wind wearing an FFP2 mask as you would cutting anything. Hopefully these videos will help if you did have any questions.
Two are up already on the PIC & VIDS section. I welcome any feedback!
Cheers folks!
The board can be cut almost in any shape as long as you do a couple of things. First, the more scores, the deeper the groove the better. Second, protect the cut line with say a level like shown as you slowly try to weaken the cut further. Like the small strip video, just move it around.
If you had a really awkward cut then a grinder would be quicker. But one thing to remember is the HardieBacker doesn't have to look pretty. It will never be seen, only the tiles on top!
Hope this helps
One Day
What’s the best bit to use to make a hole
Diamond bits work fine.
For larger holes I use an old HSS bit to quickly stitch-drill a hole and then knock it out with a hammer.
As said above - it doesn't need to look nice!
F
Flintstone
Is this on the cement boards that you don’t ever use and hate ? :D
Reply to ***NEW HARDIEBACKER VIDEOS ON TILERS FORUM*** in the Canada Tile Advice area at TilersForums.com
I'm redoing our bathroom and looking for some advice on tiling backer boards in relation to the...
TilersForums.com has been online since 2006 and we've had many designs, even three forum...
I'm going to set something up tomorrow so that we can host all your videos, no matter how big or...
Huddersfield
    Votes: 9 5.8%
    Votes: 15 9.6%
    Votes: 11 7.1%
    Votes: 46 29.5%
    Votes: 19 12.2%
    Votes: 37 23.7%
    Votes: 4 2.6%
    Votes: 2 1.3%
    Votes: 21 13.5%
    Votes: 18 11.5%
    Votes: 17 10.9%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
