***NEW HARDIEBACKER VIDEOS ON TILERS FORUM***
Rochdale
6mm is fine for thefloor but & having had to tank the 12mm I’m not sure I’d use it again in a shower. Leaning towards either regular PB & membrane or liquid tanking or Jackoboards
A grinder will always be the fastest way, 12mm is tough but also the only board in the UK that can span 600mm centres without the joints bracing
12mm only needs tanking in a wet room and not a wet area. If a standard bathroom 12mm on stud taped then tile.
I'm only Huddersfield and happy to catch up sometime?
Why does the 12mm board not require tanking ?
The board is water resitant. Water cannot damage or degrade the board in any way. The board will absorb water and disperse it.
Only reason we tank is because the product underneath hates water and will degrade. So in a normal bathroom tanking isn't required and a great cost and time saver
I don’t agree with that statement mr backer!
Who wants a soaking wet board behind there tiles ? And I also don’t think there’s any difference in a wet room and a regular shower except the floor, and floor to wall transition.
HardieBacker,
Tile_novice,
HardieBacker,
Tile_novice,
