Onlinetiler | Videos | A Professional Tilers' View On Tiling
Saw Nick at the Home Improvement show at Earls Court last friday!
He no doubt sends his regards.
Adam - how do you manage to get all the good jobs or is this the state of the industry down south?
Good posts.
Thanks.
Hi John, I'm pretty sure it's just the state of things down here at the moment. Went to look at a job last night where the lady was in tears, her re-furb was only finished two weeks ago but it's so bad she has to have it re-done. There's just such a generally low standard of work around at the moment, and with my in built **** magnet I manage to find most of it :mad2::mad2:
I seem to be finding quite a bit of it at the moment Adam. Keep up the good work mate:thumbsup:
Man flu.. another vid..
[video=youtube;MOaaJhmabYs]http://www.youtube.com/watch?v=MOaaJhmabYs[/video]
A tip for those with a dodgy level that's setting a datum line or any other general level/plumb line that's longer than the spirit level being used.
If you use a level that's 2mm out over the length of the level, you can do a 2000 linear meter and be well out, or you can just be 2mm out max!
The difference is, to get it right, you need to turn your level around 180 degrees each time you add another length on your datum.
Not sure it would have sorted Adam's issue out though :lol:
the only thing to do with a dodge level is bin it.
The only thing a dodgy level is good for is a straight edge - so knock out the vials and use it as a batten!
First job when starting setting out a room is check the level, if its not reading the same when turned around, its been dropped/damaged so 'bin it' (quote Deano).
Always get your datum/level line drawn around the whole room before you start tiling and make sure it meets up! Don't try and fiddle it across the door - it shows and it means your running out somewhere.
