Opinions please
Hi guys and girls,
Wanted to get a couple of opinions. I recently done a couple of bathroom installs and tiling for a relatively new construction company.
Whilst working on site I was asked about tiling the hallway, utility room and a family/kitchen room.
When the company ripped out the travertine floor they managed to put the kango right through the floor and hit the main water feed to the kitchen. Only 170mm down!
Thus ment all the wet UFH had to be ripped out. So, I went on Schluters 2 day course, learnt about Bekotec-therm and quoted as such to suppl, fit insulation, panels, UFH and to screed, tile etc.
Since I recommended Schluter. The company contracted someone else in to put the UFH in, and another comoany to screed. I didn't have the time so fair enough. However, I was on site still working on the bathrooms when all this was done.
Had a site meeting with the construction company and the screeders and advised what was required. For those that don't know the screed needs to be:
4:1 sand/cement
No reinforcement or fibres
8mm above panel nibs minimum and no greater than 25mm.
What has gone in is:
4:1sand/cement
Fibre reinforcement
Approximately 95-110mm above nibs!
Ive since cleared from site.
Ive been emailing Schluter as to warranty and implications of incorrect screeding. I fed this back to the construction company and we went our separate ways.
I've since learnt that despite no warranty, and advice from Schluter themselves they have contracted someone in to tile it!
80sqm, no expansion joint either.
My question is, would you inform the client!? I got on really well with them and I suspect that if they knew there instalk was not only incorrect but unwarranted they'd want it doing properly. Certainly as this part of the overall renovation on their home is costing them best part of £15K.
thanks for that ali, whats a nib mate?
Hi guys and girls,
4:1 sand/cement
4:1sand/cement
Fibre reinforcement
Whilst it has not played to the strengths of the bekotech system and will probably be blooming inefficient the overall depth and nature of the screed subject to it being properly compacted has become a standard sand cement floating screed. It should have had movement joints as normal at that depth. I would not stir up any troubles for the client personally.
That would never be my intention. My plaguing worry was the lack of warranty on a rather expensive part if the build.
I don't mind being blunt and honest at times, and as we are in the arms at least.............it's if my opinion this company will be gone within a year. The family area/kitchen was a huge part if the overall project. A project that has been a shambles from the start. When this floor fails, if the company are gone then a very nice couple are gonna be in the proverbial.
I agree with all your comments, but a large proportion of the work has my name on it, and allbeit a small portion, this floor is amongst it. I felt obliged to say something after hearing Schluters opinion, and I suppose there is a small amount of reputation protection ;-)
In both cases as far as I'm concerned.......it's not your job, or your problem. If they both went against your advice and then someone else done the tiling, then that's between the builder & customer.
You may come out as a case of sour grapes.
+1 , agree with CJ here.
Nothing to do with you , move on.
Diggy
Ali I think this might come back to bite you.
If you have told the client then hope you had 100% percent of the facts and that you know catagorically the spec was incorrect
Opinions please
AliGage,
Ajax123,
AliGage,
Ajax123,
