Discuss Please help, I made a screw up... in the UK Tiling Forum area at TilersForums.com.
tileboy
Hi guys...
I'm hoping someone can shed light on my little screw up. Right so been busy on a job for a whole heap of days...Yeah ok so I'm slow, I must be the slowest tiler on planet earth but I'm bloody neat so it's ok!!! I think it may have something to do with my training because I just don't seem to be able to tile any faster no matter what I do...
The problem slapped me in the face today...Please look at Picture A. This is the door frame around which I have tiled. The tiles are 150mm x 600mm. I tiled from the left side of the room around the top of the door (follow the red arrows) up to the tile with the red "X" on it. Then I carried on from the other side of the room till I met back to that same point. The first three tiles are 300mm x 600mm then a border right around the room then the 150mm x 600mm to the roof. The first three tiles are on the same datum line ALL AROUND THE ROOM, so it makes NO SENSE that what I'm about to explain happened.
The first three tiles from the floor up (as I said) are running the same datum line, they're PERFECTLY level so if I was to switch on my laser light and stream a line (which I did) on the TOP EDGE of the first three tiles across the room then you will see that right around the entire bathroom the line follows perfectly which means that the top edge of the first three are at exactly the same level right around the room.
Spacers are 3mm...
On top of the edge of the first three tiles comes a 3mm spacer, then a border. On top of the border comes another 3mm spacer then the 150mm x 600mm starts. So safe to say I have the same level right across the room.
Now look at picture B. See the red X ? Well, it was there that I tiled up to then stopped. I carried on tiling around the other side of the room till I got back to that point. I tiled from the floor up to where the red X is, because everything is level (I made it so) there's no reason why the tile directly under the red X should not fit. It should fit right? Thats what I though, because all my lines asre straight. Everything is perfectly level, so says my laser and my spirit level. The truth, however, is that when I reached the point of inserting the tile under the red X it didn't fit and by a WHOLE BUNCH. It was out by something like 15mm maybe more. WOW, I have NO IDEA how that happened. Everything else in the room is in proportion and fits...This one tile now suddenly is out and by a bloody long margin too!!! So, obviously I couldn't rearrange the whole room cuz the tiles are fixed now so the only logical answer was to cut the 15mm or what ever it was off of the top of the tile and fix it in there anyway. It's such a little actually off the whole tile that if you stand in front of it you can barely notice that the tile isn't the same size as the others. If you look very close, or if you have a very good eye you will pick it up but I can almost guarentee you the owner won't spot what has happened.
Still with picture B, now that I've fixed that tile in anyway....turns out that to the tope right of the room close to the roof it has somehow thrown my grout lines out by that 15mm. On pic B see the red circles? Notice how they don't align AT ALL!!! In fact, rather look at picture C....It gives a closer view of how the lines are thrown out now in relation to the red X tile. Look at the lines going down the wall and you'll see eventually (after 3 or so tiles) the lines restore themselves and all is as it should be.
I am SO CONFUSED as to how and why this happened. I did everything by the book....Now, you don't notice the cut tile in the middle of the lot but by the roof there's a clear mismatch....I'm hoping to GOD that the owner doesn't notice, there's alot of the same colour in the room and it's very hard to spot mistakes cuz everything sort of swims into each other. Where the roof is, the builder said I should leave a small gap as he is going to install a sizeable cornice there so hence the gap between the last tile and the roof. In pic C, where the mosaic strip is you will notice that there is a clear mismatch between the tile egde and the mosaic strip (this is to be covered by the cornice so that will disappear...
PLEASE can one of you bright lads explain WTF went wrong. I susupect its something I did when I tiled around the door. You know when you tile around a window and the lines don't match up when you get around the window? I think it's maybe that....but I don't know what to call it firstly and I have even less of an idea of how to explain my way out of this. If she doesn't notice then cool but between her, the builder and the architect someone is gonna see it. I have to be able to explain what went wrong and kinda in a way that makes it sound as if it aint really my fault. Ha ha...I'm not a chance taker and I feel worse than bad for it having turned out this way but it's kind of way too late to do anything about it so I had to improvise.
Then, one thing I do feel very happy about is the shower tray which I did using Travertine mosaics. The owner had no idea really what she wanted so I used my initiative and came up with something on my own. Please refer to picture D to see what I ended up doing with the shower floor, I think it looks lovely....Please comment if you can, but be nice please cuz I'm feeling a bit like a tiler's *** today.
In advance lads, thank you VERY MUCH for any help....last thought would be just to ask (again) if anyone can suggest something to help me explain my way out of this one!!!
Many many thanks....
Tileboy :))
DHTiling
Looks like you have lost your level over the door....
Personally i would pull that bit off and re-do it...looks well out of line...
You have the correct datum at the botton half but you can see you have dropped 15mm across the door...
In thoery you should have done that side all in one go, so you know you are gunna meet up..:thumbsup:..
experiance will teach you that...coz once you make a mistake like that , you won't make it again...:smilewinkgrin:
CDS
Cor blimey matey, this is a bit of an epic... I'm on my second cup of tea!!
Suggest you:
  1. Check that your spirit level is accurate (put it on the wall, level it, mark a line at both ends, turn the level around, match up one line, level it and mark again – how far apart are the 2 lines?)
  2. Check that the door frame is true – looks like you've lost it over the top of the door frame? But hard to be sure from the pics. Have you followed the top of the door assuming its level?
  3. Run a spirit level from a grout line on the far left hand wall, across the door and line it up against grout lines either side of your vertical border. Which one is level? To the left or right of the border?
  4. Repeat 2) at different heights across the door – including across the top of the door.
If it lines up to the right of your border then you've def lost it over the door frame - Redo this bit and hopefully you've got a top job!!
Hope this helps
tileboy
Hi Dave....I can't pull it off mate cuz if you look at picture A, thats where the lines are coming from across to the other side of the room. I cannot possibly see how I lost 15mm-ish from the left side of the room to the right side over the door when everything was and still is level!!! If I had to hack the tiles from the left of the door off down to the border and start again, I'd get exactly the same result....Think about it? The first three tiles are set....level. The borders are level. Above that up to the roof everything is level and the grout lines are spaced 3mm as everywhere else. If I really dropped 15mm-ish over the door then somewhere else too I'd have massive grout line pinching or expanding but I don't, it's only that one tile and all grout lines remain 3mm....It makes no sense!!!
DHTiling
All i can say is...you have lost your level somewhere...?
Are the tiles on the righthnd side of the door...bottom half level with the left side of the door....use a level not the laser...
You can not loose 15mm in that short a run without bieng out on the left or right...
i can see where you have had to cut the tile t fit and where you tile start to run out...
So looking at it...it is where the left comes across level at the doorhead, then the remaining tilies do not fit....so, the right side must be out compared to the left...
Cut a length of straight 2x1 the length of that wall where the door is,and line it up with the joints a half way then put a level on it...
you have to be out sonewhere....
tileboy
CDS....Thanks for the reply mate!!! Tea? Sounds good....milk 2 sugars thanks, LOL!!!
Well, both my levels are brand new mate so they should be fine. Then, I didn't use the top of the door frame as reference or assumed it's level as you said. I used the level created by the tiles following on from the left hand wall.
I'm only 90% sure of what you're saying here. Thing is that I can't redo that section only because I'd have to drop the entire level of the room down 15mm from the right hand side OR pick up the left hand side of the room 15mm which means I'm left with a sliver underneath the first three tiles from the floor up (on the left of the door) which I can't do because the architect design asks from three tiles upto the border, not three including a sliver...
It's gonna have to stay that way I'm afraid!!! I'm just dreading having to explain to the client why it is that way!!!
How do I avoid this happening again? I have another bathroom in the same house t do in exactly the same tiling config, pls help!!!
Thanks.....
Then, if I line my laser up with a grout line on the left wall and across the door to the other side of the door the lines match perfectly. That one tile where I had to cut 15mm off is the ONLY one that suddenly causes hassles. All the lines run true from left to right, all around the room up and down and side to side. I checked it myself, a laser level don't lie.
Gazzer
Sorry mate but there is only one way to sort it and thats to find out where you have run out of level and redo it.
That cut that you say is hardly noticable well.....sorry again but a blind man on a galloping horse could see that from 10 miles away. I am sure buider and everyone else will notice.
Do yourself a favour and sort it properly....this is the start of you career, dont start by getting a bad rep.
As for the floor...........sorry again looks awful to me.
tileboy
Hey? Not to be funny mate but you think the shower floor looks awful? Oh come on dude...Where's your creativity? What would you have done? Just tile straight mosaic? The entrance of the shower once the glass is in now has an invitation to enter. I think it looks fantastic. Anyway....You're a trained eye my friend, it's obvious you will notice it. Anyone else won't. You have years of experience I'm assuming so give the untrained eye the benefit of the doubt. The architect was there yesterday and she didn't notice anything!!! I'm not one to pull the wool over people's eyes....I just honestly don't see a way out of this other than redoing the whole bloody room. Think about it carefully, it's not possible to just do that piece over. I'd have to lift the entire left hand side of the room 15mm which I can't do...I'm not going to redo the whole left hand side of the room, logistically it's not possible.
Am I wrong here guys? am I wrong in my thinking that it's not just as simple as redoing that one section.....cuz from my point of view it's WAY more complicated than that!!!
Reply to Please help, I made a screw up... in the UK Tiling Forum area at TilersForums.com
Hi all, We employed a tiler to lay some rectified wood effect planks in a herringbone pattern…...
    Votes: 5 5.0%
    Votes: 8 8.0%
    Votes: 6 6.0%
    Votes: 25 25.0%
    Votes: 14 14.0%
    Votes: 27 27.0%
    Votes: 3 3.0%
    Votes: 2 2.0%
    Votes: 19 19.0%
    Votes: 18 18.0%
    Votes: 10 10.0%
    Votes: 5 5.0%
    Votes: 3 3.0%
    Votes: 1 1.0%
