doug boardley
great minds think alike! ( or fools never differ!!):lol::incazzato:you beat me to it by 60 seconds!!!
hello tile boy i hope i can offer you some good advice ,if you wish to learn any thing from this job you need to forget about how long you have spent or how much money you will or will not make on this bathroom , the standard of what you have done is un acceptible whether the architect or customer notices or not, you have to strip off what you have done and start again buy yourself some red wedge pegs as aswell as using your cross spacers, your levels need to be a good brand such as stabila or stanley fat max or fisco pro or use a pendulum laser level ,the vertical strip on the right hand side of the door is out of plumb and the tiles to the left of this are dropping on the right hand side by at least 2 mm per tile out of level doing anything else other than starting again will be a bodge and you will compromise your reputation and the shower floor does look awful please dont takeoffence this is meant as constructive criticismHey? Not to be funny mate but you think the shower floor looks awful? Oh come on dude...Where's your creativity? What would you have done? Just tile straight mosaic? The entrance of the shower once the glass is in now has an invitation to enter. I think it looks fantastic. Anyway....You're a trained eye my friend, it's obvious you will notice it. Anyone else won't. You have years of experience I'm assuming so give the untrained eye the benefit of the doubt. The architect was there yesterday and she didn't notice anything!!! I'm not one to pull the wool over people's eyes....I just honestly don't see a way out of this other than redoing the whole bloody room. Think about it carefully, it's not possible to just do that piece over. I'd have to lift the entire left hand side of the room 15mm which I can't do...I'm not going to redo the whole left hand side of the room, logistically it's not possible.
Am I wrong here guys? am I wrong in my thinking that it's not just as simple as redoing that one section.....cuz from my point of view it's WAY more complicated than that!!!
Well said Gary,hello tile boy i hope i can offer you some good advice ,if you wish to learn any thing from this job you need to forget about how long you have spent or how much money you will or will not make on this bathroom , the standard of what you have done is un acceptible whether the architect or customer notices or not, you have to strip off what you have done and start again buy yourself some red wedge pegs as aswell as using your cross spacers, your levels need to be a good brand such as stabila or stanley fat max or fisco pro or use a pendulum laser level ,the vertical strip on the right hand side of the door is out of plumb and the tiles to the left of this are dropping on the right hand side by at least 2 mm per tile out of level doing anything else other than starting again will be a bodge and you will compromise your reputation and the shower floor does look awful please dont takeoffence this is meant as constructive criticism
Although I have poor eye sight, I can see that the tile with the arrow marked on it in Picture B is thinner than all the rest. That's where you've lost your level, in my opinion. Have you checked the measurements of each tile in that area?
Ok guys....seems I have to run through this so you guys see what I see:
3. How can I redo it? THINK CAREFULLY guys...If I remove the tiles above the cut
piece there's going to be 15mm gap SOMEWHERE else, you see? Even if I replace
the cut piece with a non cut piece, it's still going to lift the tiles above it by 15mm
which means on the left side of the door the tiles will ALL have to lift by 15mm?
Please tell me you're getting what I'm saying here?
I've lost 15mm somewhere and the only way to fix it would be to straighten the now skewed room which means redoing the entire bloody room.
Now, is anyone in agreement with me here. To be honest all I'm getting is everything I've already considered, I'd appreciate some positive feedback not doom and gloom. I know I've screwed up, but it feels as if one of two of you are giving me hell for it which I really don't think is necessary I feel bad enough as it is...be nice lads!!!
Lol, you havent read the whole thread have you :lol::lol::lol:
And I don't read... much:dizzy2:
:iamwithstupid:
I believe a cornice/coving is going on, even so I think I'd have still yaken it to the topView attachment 3287
Ok, the more I look at it the more I think you have followed the door liner, an easy way to check this is to do the following:
Take a level and see were I have maked the dark blue line is level,
I think it will be:smilewinkgrin:
Next see if the grout lines in both the green boxes are the same top to bottom, in the picture it looks if they are smaller at the bottom then at the top, a sort of wedge shape. But pictures can be decieving so i may be wrong. TAKE NOTE: THESE HAVE TO BE THE SAME, if it is 3mm at the top and 2mm at the bottom, don't think 'oh it's only 1mm difference, that will be fine' these are quite long tiles and if you don't get the grout lines the same it can drop by as much as 6mm from one end of the tile to the other.
lastly if both of the above are true then take off the tiles i have marked in yellow and tile again, you may have to take off a few more to the left of the door, but if the tiles are level on the blue line then no tiles below this mark need to come off
Also, why have you not tiled to the ceiling? are you planning on putting a mosaic border at the top? If so, then you will have more problems if the ceiling is out of level. It would have been better to put a border 1 tile down from the top
I believe a cornice/coving is going on, even so I think I'd have still yaken it to the top![]()
Different sized tiles as far as I can see.
Edit: I stuck a ruler to my screen and the problem is definitely different sized tiles.
you're gonna have to read through all the posts mate, already covered that:lol::lol:just spotted that theres a rogue tile in there its defo smaller than the rest how on earth????? do you put a cut tile up by mistake? thats your issue that flamin tile
Don't you just hate it when people join a conversation halfway through:smilewinkgrin:.you're gonna have to read through all the posts mate, already covered that:lol::lol:
If you lost the level where I mentioned earlier, you would only have to remove 8 tiles to get it level again
I get it to nine, the ones above the middle of the doorway and the ones to the right of the doorway,from the ceiling down to and including the cut oneColour republic, heya...
8 tiles? How do u figure that one? My view is that all the lines vertically and horizontally around the room need to match up. Removing the right side wall as the guys suggest to the right of the mosaic strip and starting that point again to meet up nicely over the door will throw the back wall's grout lines out of whack by that 15mm. If not that wall then another wall somewhere else. I am struggling very hard to see how you guys think I can fix this in a simple way. I am trying though, it's just not making sense most of what's been said here. If you think 8 tiles then would it be a massive imposition on my part to ask you to copy one of the pics I've added as part of this post which best highlights the tiles ur thinking of and editing it with mspaint to mark the tiles you think I should change? If not then no worries, I'd appreciate any effort.
STRESSED !!!!
STRESSED !!!!
Well why didn't somebody say!! There's your answer, fit 3ft coving and it'll cover the wonky lines. DUH! I can't believe none of you thought of that before
