Guest viewing limit reached
Please help, I made a screw up...
Ok guys....seems I have to run through this so you guys see what I see:
We DO see what you see mate, defo no argument there
3. How can I redo it? THINK CAREFULLY guys...If I remove the tiles above the cut
piece there's going to be 15mm gap SOMEWHERE else, you see? Even if I replace
the cut piece with a non cut piece, it's still going to lift the tiles above it by 15mm
which means on the left side of the door the tiles will ALL have to lift by 15mm?
Please tell me you're getting what I'm saying here?
Yes we are getting what you are saying.
I've lost 15mm somewhere and the only way to fix it would be to straighten the now skewed room which means redoing the entire bloody room.
Yep 🙂
Now, is anyone in agreement with me here. To be honest all I'm getting is everything I've already considered, I'd appreciate some positive feedback not doom and gloom. I know I've screwed up, but it feels as if one of two of you are giving me hell for it which I really don't think is necessary I feel bad enough as it is...be nice lads!!!
The problem is that no one really worth their reputation is ever going to say "yeah, I'd leave it and hope no one sees it"
Only way really is to re-do the room, otherwise your only chancing the client to not pay for the work and trash your rep.
Although I have poor eye sight, I can see that the tile with the arrow marked on it in Picture B is thinner than all the rest. That's where you've lost your level, in my opinion. Have you checked the measurements of each tile in that area?
:dizzy2:
:iamwithstupid:
Gary hit the nail on the head IMO - "the standard of what you have done is un acceptible".
You need to make good by following Daves' advice....take off the tiles on the RHS of the mosaic, draw a straight line and make good - that'll get you out of this hole and should make things look right.
For reference, I always tile above the door last as this is where you can lose small discrepencies, although 15mm is quite a lot, so don't know what went wrong without seeing the whole room.
Good luck with resolving matters.
If you lost the level where I mentioned earlier, you would only have to remove 8 tiles to get it level again
Different sized tiles as far as I can see.
Edit: I stuck a ruler to my screen and the problem is definitely different sized tiles.
Tb i would seriously think about re doing it again the builders will see it and the architect will too when they have a good look at it its your reputation on the line here its best to put it right now before grouting stabila do a good level:thumbsup:
Ok, the more I look at it the more I think you have followed the door liner, an easy way to check this is to do the following:
Take a level and see were I have maked the dark blue line is level,
I think it will be:smilewinkgrin:
Next see if the grout lines in both the green boxes are the same top to bottom, in the picture it looks if they are smaller at the bottom then at the top, a sort of wedge shape. But pictures can be decieving so i may be wrong. TAKE NOTE: THESE HAVE TO BE THE SAME, if it is 3mm at the top and 2mm at the bottom, don't think 'oh it's only 1mm difference, that will be fine' these are quite long tiles and if you don't get the grout lines the same it can drop by as much as 6mm from one end of the tile to the other.
lastly if both of the above are true then take off the tiles i have marked in yellow and tile again, you may have to take off a few more to the left of the door, but if the tiles are level on the blue line then no tiles below this mark need to come off:thumbsup:
Also, why have you not tiled to the ceiling? are you planning on putting a mosaic border at the top? If so, then you will have more problems if the ceiling is out of level. It would have been better to put a border 1 tile down from the top
I believe a cornice/coving is going on, even so I think I'd have still yaken it to the top:thumbsup:
tileboy,
Gabor Nagyhazi,
tileboy,
Gabor Nagyhazi,
