Please help, I made a screw up...
Oh my god.... you struggled a little with the bathroom (by the way defo lost your level accros doorway imo) a simple strip above the door into wall would have fixed the prob and left you feeling better about it accepted or not i could never have left it like that but thats just me.......(and probably 99.9% of all other tilers on the forums but way hey) But as far as this next job goes take my advice and get help from a more experienced fixer because if all your lines need to marry throughout the job and up the stairs just setting from the basement and going with the flow aint gonna cut it,this one needs allot of thought and setting out 600 x 600 porc aint very forgiving and it will cost you dearly if it goes **** up........GET HELP....:thumbsup:
Duly noted mate. I think I'll do just that. It's gonna sting a bit saying no to a large chunk of money like that, maybe I should accept anyway and sell the job to a contractor more experienced than myself...That way it will seem as if it's my company that did the work. Plus then I can learn while I'm at it!!! Nice!!!
Good idea?
very good idea! although bare in mind that your price might have been cheap and a contractor would have charged more so they may not want to take the job on at your price
Well, it's not as simple as just a strip as you put it. Trust me mate. I've taken everything that everyone has said here and I've looked at the wall and at the end of the day whether you want to agree or not, the only way to correct the issue is to redo the whole bathroom. Logistically thats not possible. If you could stand in the bathroom with me you will see what I mean. Also, the client suggested I leave it that way, it wasn't my suggestion. I'm sorry but irrelevant of what anyone thinks (and here's where I stick to my guns) if the client says pink, then pink it is so I won't feel bad because I know we discussed it honestly and openly and it's got nothing to do with pride. It's called understanding and we understand each other.
As for the large job, I think I will call one of the larger contractors I know and maybe I can learn from him how to do such a large complicated job!!!
:smilewinkgrin:
What a marathon post......
There are corners, twists, turns, doors, more corners it's not a square roomed house...Setting out a dry run won't even work because even though the house is HUGE it's cramped inside so muchos cutting is no doubt gonna have to happen...Aaaah, new cutter investment it seems. My industrial cutter can only cut tiles up to 520mm. Uuughhh....Tools, tools, tools.
I need a bloody rotozip too which you don't get in South Africa!!! What a pain, cuz there's no way I'm going to cut 600 X 600 size tiles to shape around the pillars in this house by using a wet cutter to start and then nipping the rest, it's gonna look pants....A rotozip wil make a PERFECT circle!!!
Just got one thing to add.... Dont forget your drill bits!
As myself and others advised you to replace the tiles above the door it was because your explanation and the first pictures seemed to suggest that the tiles lower down on both sides of the door were lining up OK,(lifes too short to read it all again) It is now quite clear that your lines have been dropping slightly as you go round the room, A new spirit level is your first purchase and do as I do, turn the level round for each wall
Glad your client is happy:thumbsup:
I made a bit of a schoolboy error myself in the past.
Bought two colours of 600x300 tiles. Stone. And Black.
The stone were 599mm and the Black were 602mm.
When we fitted them they rose higher each time. We could have taken some off each black tile but my tiler was tired and wasnt that bothered !
To this day the white lines of the black tiles are rising higher than the left hand stone tiles.. But I live with it.
Having spent half my life reading this thread id like to add something , its crucial in my mind to use a quality laser (like the autocross laserliner or similar) especially when fitting large formats as the slightest out of level can cause big problems especially over larger areas, even with a good spirit level you can be out .. heres a pic of me using one in a floor area of 100m2 , the laser is on the right of the pic on the wall . the datum matched up 100% over the area , try that with a spirit level.. any way good luck tileboy and one last piece of advice try and hook up with an experienced fixer its the best way to learn.. :thumbsup:
What is that room used for Andy? keeping animals? looks very interesting
dog kennels !! and it was blimmin freeziing , the wind howled through the apertures for the outside runs.
there was 80m2 of white 6x6 wall tiles and 100m2 of floor tiles which the bloke got for £5m2 , they were different sizes tho hence the brickbond pattern. took 2 of us 5days and it took us one day to grout the floor , forgot to bring my kd washboy too so that was a bit of a chore , it was a nice little cash earner though!! :thumbsup:
Me and my mate done a subway quite a few years ago, no laser used he had a old theodolite, not every bodys cup of tea but done the trick
Whilst we are on the subject of laser levels, I have a cheapie rotating laser level from B&Q that I finally tried out on that wet room I did a few months back.
I was actually quite impressed. I took all my levels to make sure that the datum line was spot on and it actually was.
Having said that, I truly believe that each level should be checked, not once, or twice, but 4 times! That's twice in each direction.
Check the level, turn your level around, check it again then repeat.
That way, if your level is out then you'll know straight away.
Also, you've got to mark your datum all the way around the room when you set out. When you're going up either side of a door like that you've got to check each course as you go either side of the door. That way, you'll notice as soon as you lose the level and you can put it right.
Wow what a read !
I wish you well Tileboy but I do hope you have insurence when you take this next job on.
Best of luck :thumbsup:
feel for you lad. am a new tiler and scared of making a big mistake!!!:yikes:
keep at it!! we will all make it in the end!!!!:20:
Nothing wrong in being a new tiler - as long as you keep learning. (Just like driving a car - not exactly like an expert just because you got the licence, right!)
No offence at all, but I was just thinking that you could show the picture to customers could prove to them why the prices are what they are - to them who wants a bargain. They pay for a professional skill and should appreciate it. Can only imagine how it would have looked like if DIY... (or done by myself as not a tiler :lol🙂
Tileboy, good job that you worked it out and dared ask for advice! Good on you and good luck with your jobs in future! :thumbsup:
even if the the level at 3 tiles high is bang on you should continue to check if it is plumb and level as you go spacers wont save your life they could be slightly even by half a mm be different sizes and that could knock your lines out - by 15mm something has went wrong if it has to be fixed try pinging a line from the left hand wall to the right hand above the door frame and work off that as you have big cuts either side of the door and to walls it shouldnt show as much as the jump betwen heights across your vertical strip
I have been tiling 21 years City and Guilds and admire any one that asks for anothers advice or opinion . I do think your new levels may be at fault and I have employed tilers myself to work from my shop and would prefer a concientious slow tiler than a fast cocky one. During my City and Guilds we adopted the policy of checking the levels after 3 courses high (excesive but practical) we also had an instructor that would run a flat 5 pence piece over your work and if it stopped or fell off you had to do it again.I too am concientious and have followed the principles I was taught and although initialy I was slow and earned little. I now have a shop and am turning work away even in these difficult times, due to diligence and morals. I care about what I do and what my customers think.Stick with it learn from it correct it and move forward.
Hi....a Quick check in to everyone to say many thanks again for the huge support. I think for this post it may have been that I found it hard to bring across the look of the room and as such I couldn't quite tie what was bein given as advice into what was actually capable.
Either way, I'm keen on furthering my tiling training. I'd like to get a bit more advanced, either that or redo my training in an attempt to cement in my brain what I was taught. Since doing my training in the UK in November 2008 I think the time it took me to find work (first job landed feb 09) kinda made things a bit hazy and in the end I had to reply on my handbook as well as common sense.
I am learning daily though which is great. I just wish we had the kind of standards in South Africa as you lot have in the UK. In comparison to every tiler I come across and know, I'm actually more qualified than any tiler you will meet here. Tilers in South Africa just aren't trained, they're tradesmen that have learnt over years and don't have the framework I do from my training. Technically I'm a very capable character, I know the theory well but somehow the application of the theory leaves my cortex somewhat frazzled. Ha ha!!!
I just wish I could walk into a room and without even blinking an eye I could look at it and figure it out in a heart beat without questioning myself the way I do. Problem is that tiling takes me SOOOOOOOOOOOOOOOOOOOOOOO bloody long. G'zuz lads, I seriously do take long. It's like to the point where it's almost not even viable to be a tiler because I just take too bloody long. Now, as neat and detailed as I am doing silly things like making sure grout doesn't collect in corners when grouting, I'm shooting myself in the foot in such a big way because for instance this bathroom has taken me WEEKS!!! ok we had loads of public holidays in between but the point is that I really can't be spending SO much time on one job.
Its very annoying...
My lecturer always said to me that speed should NEVER EVER be your concern. Doing it right should be your number one concern. I think maybe I lack confidence, maybe thats it. Cuz when I walk into a bathroom I can talk my way into the job no problem but the actual doing of the job takes mind power...I struggle immensely with things like lipping and setting out and floor setting out, god forbid I ever have to set out geometrically unsquare floors or rooms. I know in time it will all come but I get the feeling that my school fees haven't even remotely been paid...
I'm a very practical person though and before getting in a panic I will sit down and try overcome the problem myself using a bit of initiative but I'm not always that lucky...Like the lipping issue. I just don't bloody understand why lipping happens when you have equal thickness tiles on an even surface...I mean WTF? Am I thick? Or is my addy bed thicker at one end than the other? If thats the case then my rubber mallet should sort that out with a few knocks by causing the extra addy to squelch out from the grout lines. This is a rather larger boil on an otherwise fairly small ***, ha ha ha (plz excuse my tone lads) LOL!!!
Setting out for me in the training centre made sense. I did it, I set out my room and I got it tiled neatly, straight, and all lovely looking. In practise though, setting out is awful for me. I really struggle with it. I measure get loads of numbers and measurements together, end up getting very confused and then possibly neglect the checklist of things you should check before laying tiles or while finding your first datum like for instance making sure you start tiling from the lowest end of the room so as to not have the possible tapering of the floor bother you at the end.
So you see guys...I'm such a keen learner, I love asking and I'm not bloody shy at all. I too, am not shy to admit my short falls and areas where I need to learn...I want to become a bloody wizz at what I do, and I want to eventually put a team of tilers together and teach them what I know so that like MTM Tiles, I too can talk with absolute confidence and run a shop....I have an advantage here because not a bloody soul in South Africa is trained to be a professional tiler, I am...Can anyone say: "MONEY" Ha ha, I know I'm onto a good thing here if I can just get my *** in gear and get more confident and start to tile faster with less hassle and less stress!!!
As usual you guys, I know I will get a mix of replies but either way I welcome the lot of you to pass on your 5p's worth...
Ta, and chat soon....
PS....Will load the finished article with pics and all once shower is in and vanity is in and bathroom is being used.
Over and out....
Tileboy
hi speed will come with experiance and practice set out is critical always double check your work and try not to think to much about money you gota crawl before you walk good luck:8:
Your lecturer were right I think and I'm sure you will be faster in 20 years time! :lol: If you rush the job you will regret the outcome and you may not have the recommendations you will survive on. (Can't be sure about that though if you are the only professional out there! LOL)
And for you being able to talk your way into any job is great! Some tradesmen (not just tilers) can do a fantastic job - and fast - if they lack sociable skills the customers may turn them down if they can't hear the confidence in them.
You hang on and you will see yourself improving the tiling.
As I have said before - imagine you took your driver licence and didn't drive for 3-4 months before you sat behind the wheel - that would have been dangerous for all of us! LOL
OMG what a long post im tired now just reading it ill make my point on it fair enough uv come on here admitted you REMOVED FOUL LANGUAGE and i admire that how you lost your level so much could be down to a few things i wasnt there so i dont know as mentioned though it does look pretty cack and in experienced has come into factor yes we have all messed up before ill admit it but i think you have bitten off well more than you can chew. You should start on small jobs first then work your way up the ladder not the other way round and as for the other work you ve got DEFINTLEY take someone with you.
There is alot of good tilers who havent got alot of work and especially work that your pulling in and it winds me up when someone inexperienced takes jobs and messes up like that.As for your customer accepting that work your really lucky to get away with that especially when there paying you. Personally i would have put it right despite whether the customer says its alright when she could have paid a decent tiler to do it right in the first place.
The lads on here have give some sound advice and are just saying what they see.
rant over:mad2::mad2:
Yeh mate as mentioned earlier...your tile looks smaller than the rest n that's what's throwing your lines out...pos that you cut a tile n put it amongst your full tiles, picked it up without knowing and used it??
These training centers are all well and good, and teach you the basics..........on plasterboards and flat ply flooring. We all know from experience that a great percentage of walls and floors are seldomly perfect.
Thats wot throws a lot of new tilers...........how and wot to do to get over the daily problems.
Your never ever to old to learn.
As for the speed issue............better to make a good job slowly.........than a bad job quickly.
Good luck to you tileboy.
Im only reading this now, hopefully long after its been sorted.
Tip for the future. Start at one side of the door, or fixed object in a room and tile all the way around using the datum line from a laser. Anyhows even doing this ive been out a mm or so. I just loose it above the door where no-one looks when they meet.
Guess what I do every time Im in someone elses toilet....look above the door, just to see and you know what i see some right messes!
If you had managed to get this above the door you could have fudged it there as opposes to either side of the vertical mosaic where it shows up more.
another thing id like to add to this saga is that you cant go on a 2 week tile course and call yourself a tiler , all the mistakes tileboy is making is down to sheer lack of experience , learn to walk before you run , dont take on any jobs you cant handle as you are cheating the customer, i was tiling for about 7 years before i totally went out on my own and even then still seeked advice from more experienced tilers...
tileboy,
Gabor Nagyhazi,
tileboy,
Gabor Nagyhazi,
