Guest viewing limit reached
Please help, I made a screw up...
No worries mate - pleased to try and help - On my third cuppa now - think I'd best turn to the vino soon or I'll be climbing walls!!
Lazer levels - Mines in the bin and has been for some time, kept making mistakes with it and too easy to knock it... spent more time releveling the level than tiling!!
New levels - If you haven't checked they're accurrate don't trust them!
If everything lines up left to right until you get to the tile you had to cut then you've def lost it over the door for whatever reason. You can sort this out by replacing half dozen tiles - Bottom line is its your reputation at stake so you need to get it sorted or you won't have to worry about doing the second bathroom - you won't be there!
Assumming you start the second bathroom try screwing baton to walls when you've set-out. (put 12 mm holes in them every 3 feet and use penny washers so you can adjust them.) Once they're up and you've got it all level you can pack the lazer level back in the van!!!
Ok guys....seems I have to run through this so you guys see what I see:
1. My laser is fine, it's had no knocks. I don't use it as a way to find my lines, I use it
as a confirmation that my lines are straight. I only ever use a spirit level to set out
my room.
2. If I cast my laser line from left of the room, to the right of the room it gives me a
perfectly straight line and level too because the laser is self levelling. SO if from the
left to the right the grout lines match (upto the cut tile) then it must mean that
above the cut tile is where I lost the 15mm.
3. How can I redo it? THINK CAREFULLY guys...If I remove the tiles above the cut
piece there's going to be 15mm gap SOMEWHERE else, you see? Even if I replace
the cut piece with a non cut piece, it's still going to lift the tiles above it by 15mm
which means on the left side of the door the tiles will ALL have to lift by 15mm?
Please tell me you're getting what I'm saying here?
I'm not as daft as I may seem...If there was an easy way out I'd have figured it out already, but there isn't. I've lost 15mm somewhere and the only way to fix it would be to straighten the now skewed room which means redoing the entire bloody room.
Now, is anyone in agreement with me here. To be honest all I'm getting is everything I've already considered, I'd appreciate some positive feedback not doom and gloom. I know I've screwed up, but it feels as if one of two of you are giving me hell for it which I really don't think is necessary I feel bad enough as it is...be nice lads!!!
There's a saying something like you have to be cruel to be kind.....:yikes::yikes::yikes::thumbsdown::thumbsdown::thumbsdown: If any of my lads did tiling like that, I would turn them into Eunuchs (a male without any testicles for those who don't know) within minutes.
Tileboy... your'e gonna have to bite the bullet and be prepared to strip tiles off one or more walls..
First, choose a wall which is horizontally and vertically level (with luck there will be one and it will be a long wall) but use a level and NOT a lazer level. Check your levels are actually level. Hold it horizontally against a wall and draw a line, then turn the level round and draw another line. Then repeat vertically to test the vertical bubble. If the lines line up, the level is good, if not throw it away..
Second, select a horizontal grout line low down and draw a horizontal level line across the adjoining walls, again, using a level and NOT a lazer level, then a horizontal level line across the remaining wall but this time draw it from each end so that the last wall will either have one horizontal level line or two.
Third, if the horizontal lines line up, you know you have lost 15mm as you have tiled up. Then it is a process of checking each horizontal grout line to see where you messed up. Once you find that point, you can strip the tiles off as many walls as necessary and rectify your mistake.
Fourth, if they don't line up, you will be able to easily see on which wall or walls where you went wrong right from the start. Once you find that point, you can strip the tiles off that wall or walls and rectify your mistake.
So hopefully, that will sort out the wall tiles....
As to the mosaics, 100% awful...rip them up and lay them in the same direction and line them up with the mosaics going up the wall...
Finally, don't beat yourself up too much about this..everyone makes mistakes, but the successful tilers are those prepared to admit it to their clients, then say how they are going to put it right at no extra cost to the client...In your case. the client, builder, architect, etc will respect you for your honesty and commitment and once put right, will feel confident enough to use you on other jobs..:thumbsup:
You could be right but without actually being on the job its hard to say what is wrong. Photos dont tell the whole story. A picture taken at a slight angle can make things look wrong.
I really hope that no one picks you up on this but if they dont i would count yourself very fortunate. The question is , can you live with it ?
Things i can see from the shower floor pic, up the wall a slither cut...again i cant see the rest of the room but i am only working here with a few pics. Against the wall the mosaic is a tapering cut and as for your design/angle i personally may have tiled the whole shower floor at an angle.
To me it looks odd but i a not the client and i am not paying.
Yeah I can see how some of you guys are not getting the feel of the room from the pics. Thats why I think you guys don't see it as I see it.
I hope too they don't pick me up on it but I don't see how that will be...eventually it will be spotted!!!
I don't want to live with it I want things to be str8 but I don't know how to fix this for one and for two how to avoid this from happening again!!!
The slither cut is an unfortunate side effect of having a full tile at the room's focal point. The focal point of the room as you walk in based on the swing of the door is the corner in front of the shower. I was taught to always have a full tile coming out from a corner where your focal point is. I could have had a half tile cut from the corner resulting in another half tile cut where the slither is but I think that would look ugly because the slither is hidden as you don't see it when you enter the room and if I were to have a half tile coming out from the corner then that would mess with the window because not only is the corner the focal point, it's where the window is too....So a slither I made it, I went for the best possible look based on focal points and what I'd rather have in a bathroom. The client knows nothing about tiling and neither does the architect so my judegment has to suffice. I know slithers are crappy by nature but if you end up with a hideous focal point just to avoid a slither then I think one is making too much of a small thing.
Anyway, I think we're digressing a tad.
The point for me now, is to figure out what I did wrong and how to avoid it in the next bathroom I do!!! Cuz I honestly don't see a way to fix this without redoing way more than I even have tiles for!!!
TB..sorry if you have recieved some harsh comments....our members are passionate about tiling works...:smilewinkgrin:...
You have 2 choices really....
1 : leave it be and pray it is not picked up by the customer.
2 : Bite the bullet and re-do the door wall.....you can straighten it up by creating a line from left to right and stick to it....the level might be out but the lines will match....
Then next time make sure you work in rows and keep checking all corners are lining up as you go...:thumbsup:....
Shower tray....mmmmmmm not my cup of tea done that way but being creative is a good thing.....this will be a learning curve for you....maybe a head ache of a curve but a good one....
thanks for the pics and good luck which ever way you go.....
p.s...members please try and be diplomatic with replys...:thumbsup:..thank you....as we do pride in being friendly..
Daveboy:
Thanks mate....I see what you're getting at but I'm at a total loss for trying to figure out how to fix this. It's simply NOT JUST A CASE OF RIPPING A FEW TILES OFF to straighten it all out. You guys have all confused me WAY more than I was before I posted my thread. I feel ten times worse than I did earlier. My client absolutely loves the shower floor she thinks it looks fab!!! So why are you guys not in agreement? Is my creativity not worth anything to you lot?
I truly feel worse than dog poo right now...cuz I've read everyone's replies which have made me feel stupid plus I have no idea how to fix this and not any of you have managed to answer my question of HOW TO AVOID THIS from happening again.
I think it must be the architrave (head) that must be out of level, and you've assumed it to be level, tiled round and down and put the cut in without trying to work out why you've had to do this. If this is the case, and assuming all else is level, you should then be able to replace the area directly above the door and to the left of the mosaics, from where it started to go wrong, to the ceiling. I think!!
Ok... I haven't had 4 hours to read all the very long posts here, but read most of yours, so sorry if this has already been mentioned
I note where you started and stopped, then picked up again.
I notice the the tile directly above the door is a straight cut, have you put a level against the top of the door liner? Did you assume the door liner was level and square? If you have followed the top of the door liner and it is unlevel you could have droped 15mm here... just a thought
Daveboy:
Sorry tileboy..have a beer :8:..we've all had bad experiences and we're only trying to help..
Tell us where you located and maybe one of us could call in and give you more hands on guidance/help find where things went wrong/advise how to put it right..keep smiling :thumbsup:
:incazzato:you beat me to it by 60 seconds!!!
tileboy,
Gabor Nagyhazi,
tileboy,
Gabor Nagyhazi,
