Discuss Please help my tiler has refused to put my tiles on the wall!!! in the British & UK Tiling Forum area at TilersForums.com.
View attachment 40735 View attachment 40736 here are my tiles thanks
I think he has a good point to be honest ,I wouldnt fix them in a wet room either
did you take a good look at the pictures Tony mesh and paper only allows 10-15% contact with the adhesive and the back of the tile the tiles can be used if you re sheet them from the front with gummed paper and then remove some of the backing but why go to the trouble send them back and get some that dont have so much stuff on the backwhy? nothing wrong with them tiles
The were brought from Porcelanosa and yes they knew they were for my wet room??
hi mike,I I dont think that would stand up in a court in the uk ,you cant do something that you know will fail even with a liability waiver from the customer or the tile supplier,since you are the expert in the fixing of the tiles if you knowingly do something wrong you are liable as you had the right to refuse to do the work or walk away from itI'm sure the shop wouldn't have sold them if they were not appropriate for that application, however having spent a fruitless 30 or so minutes trying to find something positive from the Porcelanosa website I am losing the will to live (perhaps less glossy photos and a bit easy navigation and technical data). Somewhere in the attached I am certain will be your tiles, and it will say "Usage Recommendations by Product" and one of the boxes is "shower walls". If it's ticked, and it will be (because the main website shows your exact tiles on a shower wall) then that should be sufficient to put any subsequent tiler's minds at rest....
[DLMURL]http://www.anticcolonial.com/recursos/ftp/cat.geneneral_piedra_ingles_2012.pdf[/DLMURL]
p.s. And if they do subsequently fall off the walls, then it's Porcelanosa's fault and not your tiler's...
Reply to Please help my tiler has refused to put my tiles on the wall!!! in the British & UK Tiling Forum area at TilersForums.com
