Preparing A Concrete Floor For Tiling - Floor Has Bitumen Down
Maybe an easier way for u then is to lay a thin runner that is level to the area u want to match and u can pour your latex and pull a straight edge over your runners to achieve a level surface. That might not make sense at first but here's an image of the technique. I use it myself sometimes if it's particularly complicated. Just remember to not pull too quickly because it'll drag the latex back out.
So set your runners level, packing them where necessary. Support them well because when u use a straight edge on them they will bend if u apply too much pressure
Pour in your latex and pull a metal straight edge back over the runners to achieve a level surface. Remove the runners after and fill in. It's fussy and time consuming but the end result is a perfectly flat and level floor. Which will halve your fixing time and save u a fortune in adhesive.
View attachment 73559 View attachment 73560 View attachment 73561
Thanks for that Freefall. Only trouble is I already have a layer down. I went round with a level today like this
and in some places it was around 17mm high from my datum and the bloke I am doing it for is not to amused we have already used 8 mixes on it. To do it again ?
I have uploaded a crude picture.
The measurements u've put in, u've not stated + or - your datum line. I'm assuming that 'the hump' u've marked is 5-6mm minus from ur datum, are the rest ur datum plus these measurements? Or am I reading it wrong?
They are all high including hump.
You can drill and plug the concrete every 2ft or so in a grid-like pattern. Then set screws in level with each other. Pour the slc up to the heads to give you a perfectly flat floor. Its a time consuming method if you're tackling it on your own but it guarantees you a good floor.
Hi Rich thanks for post. I think I may try your suggestion I should have done this to start with. I want to check I am prepping the correct way for setting screws if you dont mind checking.
1. Set up laser anywhere in room
2. Find the highest point
3. Mark this on datum stick (level with masking tape on it)
4. Drill holes in grid pattern 2 foot squares ( could I make squares bigger, or not recommended )
5. Raise screws up to meet datum line.
Thanks to everybody for your previous help. I now appreciate how skilled the pros are it is not easy at all.
Phil.
As long as you're level between the screws you're fine making them 10 meters apart.
It just becomes a nightmare trying to stay level when you don't have something close as a point of reference.
Cheers Dan
Was thinking that, will do 2-3 foot apart. Do I need to put any primer on existing SL. I did put some pva on thinking it was good enough to tile onto of which I just found out I shouldn't have used pva.
Evening Phil, sorry to have not replied earlier. 2 to 3 ft should be ideal. I prime slc between coats though I know others don't, however you're going to have to shift that pva sorry. If you applied it really dilute you may have got away with it. You'll have to check its soaked into the floor and not formed a skin. Good luck with it and keep us posted.
Thanks for getting back to us Rich.
The pva was really diluted luckily as it was the dregs out of a few old bottles so no skin. Have you personally done this method if so is it fairly easy to get it level with the screws , do you still have to trowel it in between the screws .Also can I just prime it with sbr without the cement.
Cheers Phil.
philrab66,
outcycling,
philrab66,
outcycling,
