Discuss problems with 600x600 in the British & UK Tiling Forum area at TilersForums.com.
Perry
Maybe its something to do with underfloor heating ,havent heard of too many probs,when that's not been involved ,just a thought,also called a couple of tilers I know earlier,they don't back skim,just use solid bed towel,,I remember,using ceramics,and vitrified tiles that were not flat backed,and never ever back skimmed.
the only adhesive you wouldn't need to back skim is PTB but i always take the tiles up when using that then rebed them a lot of guys get on them to early as well and break the bond
I remember the time we first started laying fully vitrified tiles 200x200mm learnt the lesson of sealing light coloured unpolished. But we were laying these straight to a s&c bed just using pure cement to key to the bed and there was no back skimming. They stuck like the proverbial poo to a blanket. Layed thousands of metres like that and never had a problem. Like i said, new tech and product requires new technique and parameters of use.
Oh, and good morning all :lol:
Perry
all these methods taking tiles up etc,wonder what you all charge per m2,like doing job twice I suppose,taking every tile up to rebed really?
you have to if laying 600 x 600 on a average floor and would be lucky to get 2mts to a 20 kg bag PTB inc hotels traveling and all materials what would you think one would get ?
DHTiling
It's doing the job properly. No you don't take every tile up but a well experienced tiler can tell as they press a tile down that it has insufficient coverage.
You seem to have a bee in your bonnet about working with large format tiles.
jay
If a floor has failed you need to determine the problem before trying to fix once you are confident you have found the problem take measures to not let it happen again ,all tiles require different methods of fixing it all comes down to experience and knowing your adh and its limitations
From what i can gather the adh in question doesn't seem to be at fault
deankyall
Not at all,but when I read through some of the posts on here,it sounds like they are reading from a book on tiling, reality is different,its fine quoting bs standards etc,but how many times is a job you turn up too exactly correct?,maybe its different up where you are,but if I walked away from all the jobs due to say incorrect ply,etc then I wouldn't have done much work,of course a tiler knows when he's bedded correctly,of course you check when you start laying,but to say "i take every tile up and rebed" is something I don't believe.especially when your trying to earn money on a price,which is why I asked how much would you have to charge??,because I know that its not feasible on what bloke would be charging down here.
DHTiling
I agree, i never take up every tile.. :)
As for BS5385, well as an advice forum we have to advice the correct way to do things as not only tilers read the info but so do the public..
Now a tiler knows his limits and his tricks of the trade but they should still be installed to standards that you were taught etc even before BS5385 was introduced..
B5385 standards were introduced to show the minimum required from a tiled installation ... so if you disagree with what members advise is the standards then in all honesty that is your choice... but we must as to the best of our knowledge help members who as show them the right procedures..but we all get things wrong sometimes, hence why all input is welcome.. :)
Perry
i laid the river island in Croydon every tile on that floor was laid and taken up and re bedded because we are not given the luxury of a clear floor to prepare they dont even screed the floor sometimes to save money we have to lay on concrete which is just brushed in wet with a broom that takes a little skill and then we don't get 1 sq mtr to a bag and no they don't pay us any more ask Alan P he has worked for me when i am doing a domestic 300 x300 no i don't take every tile up and would you believe this some of my guys can lay 50 mts a day on a bumpy floor
adam.s
First time poster long time reader :smilewinkgrin:
Would you think that this could be a primer issue as I have a job onto particle board flooring with PCI nanolight and the tile has de-laminated off a 300x600 porcelane tile. I was sold and reassured that I could use another brand of primer than PCI specified Grisogrund 303 primer. If for say this primer did not allow the tile to dry out in the same/relative time as the sub-straight being particle board and sucking a lot of the moister out before the tile getting full bond would this have major effect on the adhesive?
Dont shoot me for saying this but what are the..... is there any difference in the make up of primers??
Product used with 10+ years experience + 1 bad but enthusiastic salesman
Particle Board Sub straight
UNI Prime (Primer) RLA Polymers
BASF PCI Nanolight (white) Adhesive
Any help on this matter of primer and new technology adhesive working with porcelain tiles would be a great help.
Many thanks.
adam.s
Yes it was a floor.
I have always used Mapei kerabond and Isolastic in the past.
On the Nanolight bag it says it can be directly put onto wooden sub straights.
I was sold this with the reassurance that it could be used for this application.
What my real question is though by using a different primer has this not allowed the adhesive to set in time for a bond to form to the porcelane tile?
Does the 303 give the adhesive a longer set time for these bonds to form?
Reply to problems with 600x600 in the British & UK Tiling Forum area at TilersForums.com
gamer1
Hello, We will be tiling our ground floor which is screed with no underfloor heating. The area...
I got 100 square metres of tiles laid 18months ago. after 7 months i noticed tiles starting to...
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
