Profile gauges.
  • Thread starter Thread starter wivers
  • Start date Start date
  • Tags Tags
    usa
wivers get your profile gauge , tie a large brick round it, then row 5 miles out to sea and throw it with all your might into the great blue yonder!!!
take the bloody toilet out and basin!!!! he he ....i usually do it by eye and tape measure same as dan!!!!!,my mate uses paper too....,i have old pieces of waste pipe and soil pipe to mark round for toilets and sinks..works well
Basin, pan & shower always come out. Won't do the job otherwise. Have tried the 'cutting round the sink' work in the early days, and it doesn't float my boat. And 9 times out of 10, the finish is crap & adds unecessary time to the job.
Decorators lining paper one roll lasts ages best by far for toilets if you have to leave in situe. get yourself some off cuts of old waste pipesand use them as templates.
Every one reckons they are no good because once you have got your shape you don't have any indication of where to place the gauge on the tile (and rightly so) but this from Rubi may solve that problem.
Anyone on here used one of these?
1st option get the pan and sink out, best finish but more expensive as plumber involved, tried a profile about 15 years ago to see if it would make life easier, it didnt, never lined up, and not a perfect cut as pins kept moving about when trying to mark the tile, the answer is to scribe to the pan perfect results every time, and fast when you get used to it, couldnt be bothered with the paper and cardboard messin about when covered in adhesive and the added fact of carrying about cardboard and paper for everytime you need to scribe round soomething to much hassle
Hi , THe best way is to take the pan and sink out - makes a far better job. I come from a Karndean/Amtico background, where the shop had to go round fittings - I used to carry a roll of 2.5mm Twin and Earth Electrical Cable round with me. Its easy to bend round curves and holds the shapes with speed & very little mess.
Profile gauges.
Tags Tags
usa
wivers,
wivers,
