Pva Versus Primers | Always Use A Primer When Tiling, And Not Pva
Re: P.v.a. Versus Primers......
I've not used bal primer, but I'm always prepared to use an sbr dilution of 1:3, (sbr: water), I do keep bottles of ultra, flex prime and Primer G in my van for when I use said addy's:thumbsup:
I've removed a laminate floor at my house as it was always spreading at a certain joint and im sick of "jump & sliding" it back together. Dont tell me you dont know the jump and slide "move" cos i know you do!!:thumbsup:
:lol::lol: I thought i had the copyright on that move!
here's a question for you all...
anyway, the reason it kept popping at that certain part was down to the gargantuan drop the bitchumen/ashphalt floor suffers at that point. I intended to self level and tile, but after ringing BAL technical this afternoon to find out the best primer (not PVA) to use on Bitchumen, only to be told they dont recommend doing anything with bitchumen other than removing it completely.
Removal is not an option as this was poured in and floated in when i bought the house (built circu 1927) to act as a damp proof barrier. Its not a thin layer originally used to fix vinyl tiles etc, im sure you will all know what i mean?
So whats my options here? I've been and bought BAL Bond but im at pains to just go ahead and use it without asking first. I intend to tile the floor in the end by the way.
PCI do a self adhesive bitumen faced membrane which is fleeced on the side you tile..perfect for sticking to bitchumen...:thumbsup:
Blimey, i am the untrained but have used PVA at home and wont use again - i do have a litre of tilers primer unopened which i thought was just rebranded pva !!
Now I have a garage floor to sort out it has never been treated painted sealed primed PVA'd ect. and went out and bought a big tub of pva to put on to "seal?" it whilst i decide weather to use an epoxy type paint or standard garage floor paint - one manufacturer of the epoxy says not to pva and now i can see why ! ....but would Palace tilers primer (the 1l unopened bottle) be a suitable product to put down as a temp fix and then paint at a later date?
Sorry if painting is offtopic on a tiling forum
Epoxy paint over PVA not really anything to do with the issues about PVA although your paint would still peel off. This is because epoxys depend on mechanical key and as such need to achieve a certain level of penetration into the substrate so that they can grab onto it. If you need to rpime the substrate you should use a penetrating epoxy primer. This will penetrate inot the surface and provide "grab" but as it has penetrated it will also have a contoured surface following the conours of the concrete thus providing a surface that the paint can mechanically bond to.
Great advise to me as a newcomer to tiling.
much better to spend a few quid more doing the job right, than getting a bad name later, costing time and money putting it right.
what about webber pr370 ? thats described as - a synthetic water based pva concentrate for sealing and primming building substrates. is it ok to use that prior to tiling then ? !! im confused !!! lol
My gosh - what an exhaustive read from start to finish! that was - :dizzy2:
i can hardly get anyone over here to even use a primer/sealer let alone discuss which type is best! - but it would seem to an outsider that there is a bit of confusion in terminology going on & some untrained adhesive reps & others might some times unwittingly profligate the problem.
I believe we should seal a substrate which is thirsty so that the adhesive cures proberly or we should prime a substrate that is suspect or hard to stick to and if neither of these is the case don't bother - the adhesive is tested without and is more than capable of bonding to most common surfaces.
Primer G diluted 4-1 for sealing
Primer S water resistant primer
Mapeprim 2 part water based epoxy for problems
p.s. sometimes it isn't a matter of can we bond to a particular substrate - but should we -i.e. bitumen - chip board etc. we stick to them but they don't stay stuck to themselves and delaminate.
Hi,
So if you already have coated the rendering with PVA how do you get it off so you can apply primer? I never knew tiling was so complicated!
Thanks a lot Christine
enduro,
Dave,
enduro,
Dave,
