Pva Versus Primers | Always Use A Primer When Tiling, And Not Pva
Re: P.v.a. Versus Primers......
What made you apply pva to render, did you thin it out or put it on neat
Quite thin so may have soaked in, could (in the shower area) apply hot water and using a scrubbing brush on the surface and clean water to remove any residue
do we then prime it when dry? Do we just prime the other walls on top of the unibond or will that then be a case of the adhesive just sticking to the primer which is sticking to the unibond! Never knew tiling was so complicated perhaps someone should introduce an "idiots guide" for people like me!
How do we prepare the plywood floor ? thanks a lot
Should have no need to prime render unless it may be dusty, leave the other walls as the unibond you put on was quite thin.
i take it that the ply is already down, normally the ply would be primed uderneath where it sit on the floor boards and edges to stop any moisture ingress, check the information on the adhesive bag wether it needs priming or not on the surface your going to tile
I am tileing over old ceramic tiles,was told to unibond pva over old ones first,Wrong??????
Hi
I have a recently plastered en-suite which has a 50/50 emulsion primer on it.
I want to tile the whole room and am going to use BAL Rapidset adhesive - do I still need to use a primer such as BAL primer??
Any help would be gratefully received.
yep! - just wash the old tiles down propery & use something that will bond direct to the. i like Mapei Kerabond plus/isolastic50 - been using & recomending it now for 15 years without 1 single problem - easy!
Hi
yes Rainbow, especially if it's a gypsum type plaster:thumbsup:
