panceramicsltd
Always use it especially when only doing a smaller floor saves carrying another bit of kit
Its not about the size it will work with any measurement eg. mark 300mm one way 400mm another and to make a right angle the distance between both measurements should measure 500mm. any measurement x3 then x4 will make a right angle when the distance between your marks is by x5.
Brilliant thread, very illuminating. All posts (well the sensible ones) have been duly noted and this will be something to go into the paper alongside the pinch rod posts, thanks!![]()
Thought you used £50 notes for measuring GeoffJust thought I would bump this thread again. Remembered the thread when using the 345 method yesterday and thought it is bound to be of use to someone for sure
Only if you cannot add up or multiply @antoniowith all the technology available, serve yet 345?
I think it is easier to make mistakes, using 345 or not?
add or multiply what?Only if you cannot add up or multiply @antonio
