mike s
I need to remove a radiator to tile the floor , ive removed them leaving the valves in place before but never just the copper pipe sticking up from the floor , if i shut off rad at each end drain then remove the valves.
will i still have to drain the whole central heating system?
It's a groung floor radiator so wont all the water in the system all just flow to the lowest point Ie this radiator.
thanks in advance
thanks in advance
