Discuss Remove plinths for tiling a floor? in the Canada Tile Advice area at TilersForums.com.
Why not lay the tile down next to plinth add 5mm for adhesive/2mm gap for silicone then cut them off with a multi master if you have one?
Leave it up to the client,i tile and that's it cosmetic issues I leave to their choice if they want to get kick boards cut down to suit give them the option of a joiner,when you deviate from your trade that's when problems happen in my personal experience.
Yup, the correct answer! Handy tip for pulling them off is using tile sucker on them. Personally never leave them on, such a neater finish tiling under and trimming.I disagree. If it's something a trade comes up against a lot then they should be able to do it as part of the service. In my mind a tiler should be able to disconnect a toilet and put it back in... cut some kickerboards down... patch plaster the odd bit of wall. It's not as if these aren't daily occurrences which tilers come up against and these basic jobs aren't rocket science!
Back on these kickerboards that won't budge... is it a very old kitchen? or a bespoke hand made one? if neither then they really should just pop off as they should be on clips.
As for tiling up to them, personally I hate that look and it is always useful to be able to remove kickerboards... also before you do go blindly tiling up to them, please open all the cupboards to make sure there are no integrated appliances which will never come out again if you do!
but you can all cut down ply to fit a floor right????? :mad2::mad2::mad2: Or I suppose you all pay you chippys to come in and do it for you?
Reply to Remove plinths for tiling a floor? in the Canada Tile Advice area at TilersForums.com
