Perry
i found when they get a little wear you can grind the braker but it dont last for long you have to bite the bullet and get a new one
ive been having the same problem with my ts 60 , what i think is the spring which need to be replace , im being a bit lazy not to order one , but i will chnage the spring and wll see if it makes any changescheers for all the prompt responses guys! its not porc, its any bloody tile!
i've got it against a ts plus to check for similarities but because the breakers seem to be different i can't seem to get them to mirror each other in motion.
i wasn't sure whether you could service the breaker or adjust the lever action.
once again, thanks for the welcome, it makes a nice change to getting your head bitten off for only turning up with your begging bowl grovelling for help cheers
good evening chaps, my rubi ts 60 (not a plus) is not breaking the tile as it should.
the breaker seems to move upwards before pushing down and the downwards motion is not completed before the lever arm hits the tile.
does this make sense?
the lever does not spring back, it seems the lever, not the breaker is breaking the tile - but incorrectly because it is not breaking the tile in one continuous piece.
any thoughts? cheers
