Discuss Rubi TS40+ cutting off square... in the British & UK Tiling Forum area at TilersForums.com.
Morning all,
I've had my TS40+ just over 12months now but since before Xmas it's started cutting off by about 3 or 4mm:mad2:
Never had this problem with my old bog standard TS's:prrr:
I contacted Rubi when it first started happening - waste of time:thumbsdown:
Anyone got any ideas on what it might be or how to sort out the problem?:smilewinkgrin:
I saw a rubi rep checking rubi cutters for squareness at a show once he put a square up against the stop bar and ran the wheel up beside it to check. if they were running out he loosened the stop bar fixings screws adjusted and retightened until they were square again hope this makes sence and helps...
That's what I suggested doing to the Rubi man I spoke to and he said there was 'no way in a million years that the stop bar would go out of square as it was machine engineered square with the bolt holes...'
I think if a new ten quid cutting wheel resolves the prob, I'll be over the moon:hurray:
OK, replaced my cutting wheel last week - no difference at all:thumbsdown:
Anyway, I was waiting for a decision about border height from the architect today and decided to give my TS40+ a good overhaul:thumbsup:
I stripped it all to bits and gave all parts a good clean and spray with Silicon spray:thumbsup:
Marked a 300x300 tile with a square line straight down the middle and proceeded to align my rails with the line on the tile which I set hard back against the still loose stop bar.
Once I was happy that the cutting wheel was square with the line and the stop bar, I tightened all the hex bolts up:thumbsup:
Hey presto - one perfectly square cutting TS40+ again:hurray:
How happy am I???
The muck and grime that came off the separate parts was incredible:yikes:You really think you're looking after your tools well until you take them to bits:mad2::lol:
Reply to Rubi TS40+ cutting off square... in the British & UK Tiling Forum area at TilersForums.com
I'm looking at a nice manual cutter from rubi. I'm set on a rubi as their parts are easy to get...
5K
Hi All, hope you're all busy and well. Quick query: setting a floor with Porcelanosa 660 x 440...
5K
Italy
I
So, I bought my first home with my wife after saving for about 10 years and have been thrown...
9K
Hi all Having a bit of a mare; after having my last shower installation botched (but thankfully...
7K
Perfect Tiling
Hi all I've noticed that when cutting large format porcelain on my Rubi TS70 plus that I...
6K
Dumbo
    Votes: 9 5.6%
    Votes: 17 10.6%
    Votes: 11 6.8%
    Votes: 44 27.3%
    Votes: 21 13.0%
    Votes: 38 23.6%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.7%
    Votes: 19 11.8%
    Votes: 17 10.6%
    Votes: 8 5.0%
    Votes: 5 3.1%
