Discuss Shower enclosure problems in the British & UK Tiling Forum area at TilersForums.com.
Sedated
Mike, Yes the gap between the floor tiles and wall tiles should be siliconed but TBH if it was so then i wouldnt see the water leaking out and I'd be oblivious to this!
I sprayed the shower head here
There is only 1mm of gap at the most between the tiles on wall and all around the tray so its hard to get any substantial bits of Silicon where the uprights go, as said previously I think that as the gap I have filled behind the uprights was such a small gap the slightest movement has caused the seal to fail. ? I coldnt put a big blob on as the fitter put the u shaped fixing right down to the bottom of the tiles, infact it was resting on the tray.Perhaps the fitter disturbed or scraped the sealant putting the cubical back on?
AliGage
Subscribed
4,531
1,188
Peterborough, England
i've never seen one where the channel fits into the enclosure, always the enclosure into the channel
That was my first thoughts. Don't think i've ever fitted one like that before. But it is bathstore, i've fitted quite a bit of there furniture, that can be quite challenging!
AliGage
Subscribed
4,531
1,188
i think he means can you take a picture of the enclosure as a whole and the installed shower as well??
Yep.
From everything that has been said and described over this post i'm not convinced it's coming through the tile round the back and out onto the floor. If your insisting the Silicon on the outside of the enclosure is dry when this happens then it may be a plumbing issue from say the shower.
Reply to Shower enclosure problems in the British & UK Tiling Forum area at TilersForums.com
I could use some help from everyone! The floor mosaic tile was recently retiled over a tile-redi...
    Votes: 9 5.6%
    Votes: 17 10.5%
    Votes: 11 6.8%
    Votes: 45 27.8%
    Votes: 21 13.0%
    Votes: 38 23.5%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.6%
    Votes: 19 11.7%
    Votes: 17 10.5%
    Votes: 8 4.9%
    Votes: 5 3.1%
