Discuss Shower from hell in the British & UK Tiling Forum area at TilersForums.com.
gixer
Hi all newbie here so take it easy on me :smilewinkgrin:
Ok so just ripped out an existing shower , it had recentlystarted leaking through to downstairs . Originally done by a " proper " tiler , so thought to myself , with the right advice , i think i could do a better job myself .
This is were you guys come in :thumbsup:
I will try and stage my questions as work progresses rather than bombard everyone with 101 questions right at the start .
So to start the floor needs re-tiled , slight bit of water damage on existing chipboard floor .
Am i better to lift and replace whole floor with WBP ply and treat the ply with Bal bond SBR ? bathroom pics 001.jpg bathroom pics 002.jpg
I have attached a couple of pics which i hope will help
Many thanks Gixer
gixer
Many thanks for the informative replies guys , whilst waiting for my first post to activate i went ahead and started to lift a small portion of the floor to aid the drying out process bathroom pics 003.jpg bathroom pics 004.jpg bathroom pics 005.jpg As you can see the old shower made quite a mess .
So to recap next step lift entire floor (as chipboard should probably never been used in a shower room in the first place) replace with 18mm wbp ply , treat underside and edges with Bal bond sbr , then some 6mm hardieback board stuck on top of the ply with tile adhesive and screwed .....
Now i have exposed the joists do i still need extra noggins ???
Thanks again Gixer
gixer
Ok guys , so i have my new ply screwed down and primed underside and edges .
Do i need to apply SBR primer to topside of ply before putting my cement board down ?
Problem no 2 is the cement board , when i asked local builder merchants they hadnt heard of it or didnt stock it .I did manage to find one that got some in for me but i,m concerned it may not be the right stuff , it is white in colour and looks more an asbestos replacement board . One side is shiny and one side has a bit of texture , it is called resistant multi pro , and the merchant said it is water proof .
Your thoughts very much appreciated .
Regards Gixer
gixer
Thanks Sir Ramic ,
I just googled it myself , appears to be a local firm manufacturing these so i will give them a call in the morning , but i fear i have not the right boards as their site lists board sizes of the Moistsure as 1200x1200 or 1200x800mm and mine are 2400x1200. Thankfully i have not started to put them down yet .
Regards Gixer
gixer
Quick update on my wee project ... phoned cement board manufacturer who said the board i have is the same as their Moist-sure board only they cut it into smaller sizes for convenience .
So proceeded with putting my boards down.. View attachment 31363 View attachment 31364 So tomorrows project is to fit 12mm cement board to the one stud wall .
On the other solid wall should i be stripping off the existing render even though i propose to tank both these walls ?
Other question is when fitting the shower tray ( which i presume needs done prior to tiling the floor ) is there a better way to raise the shower tray other than wooden studs ?
Thanks in advance Gixer
So View attachment 31365
Reply to Shower from hell in the British & UK Tiling Forum area at TilersForums.com
  • Sticky
F
Good evening all. I need to tile the kitchen floor over the bank holiday weekend. We are having...
13K
Futuregrout
F
Hi Thanks to all who provided advice on my bathroom project 3 years ago, tiling both the...
swanman
E
Hi, Upstairs ensuite with T&G floorboards. Entire floor overboarded with WBP ply. Area under...
8K
K
Hi, I've been getting conflicting advice about whether I should put a DPM behind the marine ply...
6K
Kester Ratcliff
K
Shower from hell
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
