Discuss Shower problem in the UK Tiling Forum area at TilersForums.com.
The tiles that are still up and have come away from the wall are ony being held up by the grout. Pull one of these away and the whole lot will come down.
AHHHH,so this jub has just been done by a builder recently and also badly
if this is the case you are within your rights to refuse any suggesstions he is making to fix this as they are bad ones
take the advice of here and make him start agin at his own cost or take him to court
I dont get it. How is it possible that gypsum is waterproof?? or maybe i understood wrong? All wet areas should have been tanked, especcialy in shower . Use flexible sealing compound to make surface waterproof then tile on adhesve class C2. In my opinion gypsum material cant be waterproof and it is very big mistake to tile on such a surface in wet areasWhitebeam
It's a gypsum finish on a cement undercoat.
The plaster get very wet when the shower leaked but it is undamaged, therefore it must be waterproof.
I think it's been tanked.
I reckon your builder originally had a guy fix some porcelain floor tiles using a ready-mixed tub adhesive which was not designed to fix porcelain, nor tiles of that size and weight. The vibration, expansion/drying out of the premature and over-polished gypsum led to a complete and utter classic builders mistake. To use PVA anywhere, and at anytime in a tiling installation is a mistake, but to pour it down a void behind a tile will only result it running down the inch-wide voids in your wall and sticking your kettle to your kitchen work surface (for a day).
Reply to Shower problem in the UK Tiling Forum area at TilersForums.com
