shower waste over joist
Hi janzbro,
I've seen far too many problems that come as a result of someone (usually the plumber or the tin knocker) hacking a joist up. I would not for any reason cut the joist the way you need to do to get this shower tray to work. Maybe you can sell the tray that you have and recover some of your expense, and then buy the new one that has the correct dimensions for the drain ?
not an option Sim, waste in same place as the one I have
Im going to pack it with WBP ply and then tank with tanking taping and Mapei WPS
nogins running between cut joist and next or either side ?
and what size (same as joist )
its an 8" joist btw and I'll need to remove 5"
A BIG NO NO YOU ARE NOT ALLOWED UNDER BUILDING REGS TO CUT JOISTS FOR PIPES :yikes:
ok point taken, Im moving tray forward as stated but how do you run basin wastes etc must these all above floor level and boxed in? , Ive seen loads with no visible pipework so it must be under the floor and damn lucky if no joists in the way :smilewinkgrin:
Alreet,
I would cut the joist if I were you n noggin the cuts to the joists either side (or double up the noggins if you'd feel safer). Use good fixings n you'll be home for supper :8:
Alreet,
Bruv, did you not read this thread properly, he wants to cut 5" out of an 8" joist, big no no.
Tags Tags
shower usa
janzbro,
Alan.P,
janzbro,
Alan.P,
