Price for a 16m.sq floor in unfinished / uncalibrated slate - probably going to be a 4 tile pattern?
Need to lift existing tiles, level floor (solid) and seal. Price including all materials will be gratefully received as mine looks way too high at the moment!
Moneys not really a problem for the cm but doing work on 2 bathrooms for them already so don't want to overcharge! Ta very much. Chris
a honest price would be £52.00 for uncal slate, as there is a more work , sort out the size difference 1st , i would recommend to seal before you start which means they need to be cleaned, check the tiles as they can split apart- adhesive cost are higher than normal and i would allow 7-10 bags , addy choice is important and thick bed addy is required .
i hope its sound advice and helpful as i been laying slate for years
Think you guys are bang out of order, the guy is a pro Tiler and a member of the tilers forums arms, he asks a pricing question in a pricing forum and gets a verbal, his spec was reasonable and if u look in lots of past posts they are the same if not less detailed, and there are plenty past posts where no figure was supplied by the person asking for a bit of help, and figure was supplied no probs( see slate price question by tedley34 about 20 posts ago)
This kind of response will lead to tilers of all experiance, not wanting to post a question for fear of sounding silly or being put down,
I try and help out If and when I can, because in truth if it wasn't for this site and the help I have recived when asking questions, I wouldn't be tiling to the standard I do now, I know this is a forum and each of us are entiled to our opinions, so here is mine if you can't be helpful, postive and decent don't be anything at all, Right rant over,
It is with replys like the ones CDs has recived
Good one TJ,you forgot the temp secratary to write out the invoice,but yeah I think buddy is looking for someone to do his bidding for him,but I'll give him this,over here I charge 2 dollars more per square foot when laying natural stone(slate ,travertine)so say I'm charging $4 per sq ft for ceramic and porcelain,then I'm charging $6 per sq ft for slate,hypethetically,sorry Dave and Dan if I wasn't supposed to write that on this blog,if I need to be corrected please e-mail me,thanks,Mike
