Guest viewing limit reached
sockets
  • Thread starter Thread starter TheWrightTiler
  • Start date Start date
  • Tags Tags
    usa
Dave's done it before the quickest way but if its a slab 20MM plus thick some times use a grinder
Gaz jigsaw blade not much good on granite a lol
plunge cut of grinder after scoring with dry rail cutter. Then just finish off with nipps.
grinder with wet sponge never dry cut it
Be extra careful when using water next to electrical tools that arn't designed to be used with water.... or you will be doing a strange kind of dance......:grin:
not quite that daft Dave :8:
no answers on that one :lol:
Hi Mate,
I would probably try and make a hole with a hole cutter and then do the rest by file and parrot nips.
Do you other guys think this is one way to do it?
try plunge cutting a tile with your wet saw its the easiest way ive found but wear googles as the bits fly up at one hell of a rate
115mm grinder always does the trick and if that doesnt work for u then do as the previous tiler said get hammer and chisel out lol
sockets
Tags Tags
usa
TheWrightTiler,
Perry,
TheWrightTiler,
Perry,
