Discuss thoughts on my design needed in the Canada Tile Advice area at TilersForums.com.
K
kevwatkins
Hi Folks i was wondering if you could cast your eyes over my design for my next wetroom.
The room is 2500mm x 2100mm with a 1200x900 wet area with glass screens to 2 sides.
There would be a 300mm bench on the left hand side of the shower area with the 1200 former starting at the edge of the bench giving a total width of 1500mm
My concearn is that as it is there is only 1000mm left to get the 600mm sink in. I was thinking of building out the wall behind the sink to create a shelf and bring the sink closer to the edge of the screen for easier access.
Any thoughts would be greatlyt recieved.
Cheers Kev:smilewinkgrin:
AliGage
Subscribed
4,531
1,188
Peterborough, England
Move the shower onto the bench wall (reducing the length by 300mm) and increase the width by 300mm instead. You'll save by only needing one panel as well if you construct the wall where your current end panel/screen is. That will then give you a space of approximately 1200mm to fit your basin (allowing 100mm for a studwall)
I know this means the basin is sat in more of a "recess" but with the extra width you should get the space you're after.
Alternatively move the basin onto the left hand wall, ooooooooooorrrrrrrrrrrr (and this is what i would do if it was me) keep pretty much as is but swap the WC and basin locations around.
Reply to thoughts on my design needed in the Canada Tile Advice area at TilersForums.com
Good evening to all. I’m here this evening looking for some advice if you would be so kind...
Hi guys I'm going to try to tile my bathroom. On the pictures you will see two old window...
White Room
Hi all Interested in views from the trade world about how I should deal with a big floor tiling...
2 3 4 5 6 7 8 9
41K
11K
Rizzle from the Portizzle
F
Hello everyone. I am over here in the USA, but noticed, when googling for info on Mapei grouts...
19K
Mr Tiler
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
