Tile Levelling Kits
We say it to make you repeat again and again Antonio! 😀
they do not break
they do not break
they do not break
they do not break
they do not break
they do not break
they do not break
they do not break
excuse me.
but many times.
I seem to speak to wash dishes 😉
Hi all
I've always levelled a floor with rapid set and cement board plus spirit prior to tile up to now. Am I missing a trick here. Are they any good?
Si
I ordered clips & wedges from Italy, very similar to Raimondi but a lot cheaper.
When you say you level a floor with cement board & rapid set what do you mean?
Are you dry lining the floor with the cement boards?
I ordered clips & wedges from Italy, very similar to Raimondi but a lot cheaper.[/B]
Going to be trying those next week let you know what I think.
Just used my 3mm clips earlier on a small floor, good but the tiles were bowed so still a bit of lippage that you would never get rid of as they wanted it brick bond.
Did you use the plier tool with them @Stef, i've only used the lash ones which I thought where great but I'd I think if doing large areas the old thumb would take some stick.
Just used my fingers, I've got Raimondi pliers but don't use them much.
I've got Genesis lash clips & they are garbage, these clips have a flat base & are good to work with.
Tile Levelling Kits
oompedoomp,
Stef,
oompedoomp,
Stef,
