Tilers straight edge!?
same as mr boardley, andy, phil and stew
but if you DO want a place that sells all varieties of straight edges, box section rules, flooring rules, etc etc, then you cant find much better choice than at refina.co.uk
and if you want a a place to buy your baton stands, then theres www.tradetiiler.com.. All angles covered now ;0)
I usually do bottom cuts first and hardly ever use battens, I just find it faster and easier.
Daz
usually cut first row in but I too have rubi stands and use some metal chanelling,very handy on floors too as its perfectly straight with square edges,saves you getting your levels dirty
Thanks all.
Screwfix sell a 1800mm box level for £18! think i'll grab one and use that. Cheap as chips!
great spot mate, thanks! I need it for tomorrow but not massively early. Might be better than the spirit level!
They do a range of options for delivery (and feather edge lengths) best thing to do probably is call em mate.
I was also going to suggest a feather edge. I have not used it on walls but find it handy when laying the first row on a floor. I hold it place with boxes of tiles and tile against it.
it was me 🙁 sorry mate!
edit: where in the world are you? you could borrow it if you are close?
davemul,
mattle40,
davemul,
mattle40,
