Tiles bowing after fitment
Can't be at £70m2 :fearscream:
I've just had 45m2 of 1500x750 delivered from Italy for half of that .
I did get them at cost mind , but even at full price the ain't much dearer :tearsofjoy:
It was defo £600 and something, £680 or something like that but it did include grout and adhesive etc, I know the cost isn't always a guide to quality but I don't think they are poor tiles
Go on mark 🙂
If I'm honest, you do seem a bit ocd Pete , you have got to be a engineer ?
I'm all for a good job, but you are talking MMs (not the chocolate treat, the measurement 😉)
Which in a man made product like a tile it is well wihin BS :fearscream:
Personally , owt 600mm or over is and can bend slightly , it even mentions it on some boxes , even lash clips won't help matters .
i doubt any tiler would stay on the job if you came in with your 12" ruler and pointed out a 1mm gap:tearsofjoy: , big lippege , yes it's the tilers fault , slight, and I mean slight bowing, it's usually product error :flushed:
I'm not having a go Pete, we are all entitled to our opinion mate ,but it does have a ring of a bit of OCD :yum:
Don't get me wrong, I am not going to start ripping them off, I don't do this as a job and I am taking my time trying to get it looking good and have found using a straight edge handy as a guide to getting the tiles flush. I need the extra help because I am not very skilled at the job (if at all !). It just puzzled me why they were pulling in and wondered if I was doing something wrong that one of you could spot or he maybe had before. It is only a mm or so and not a big deal just a bit strange.
Cheers Pete
1.5mm skim on the tiles are porous dries instantly.(you see at grouting it's dries instantly) On the wall you started you can't change for different skimming but you can do on new wall and see if it works. You get more adhesive needs for sure just make sure you calculate extra
3-4 mm skim on the tiles is with the teethed side not with the flat just to make sure 🙂 I do vertical on the wall and horizontal on the tiles usually.
One more thing
These tiles usually have a little lip on their edge at their back goes around while centre part is not
Thanks both,
I am going to try with some Rubi levelling clips as these are 4mm when not tensioned where as the lash ones are more like 6mm.
I guess when tensioned the lash ones perhaps go to 3mm at a push but they would have to be really pulled tight.
I will let you know how I get on, thanks again.
Ciao, Pete
How are you getting on with the Rubi straps Pete?
Bed you're loosing the will to live aren't you?😛
It's a bit of a mixed bag really, I do like the fact that they are slimmer but I am not so sure that they go as tight as the lash system, also for an amateur the lash system is nice and easy to undo and re-tension.
I gave them a soak and tried using both one cup and then two as you suggested and they did the job.
My next job is helping my Daughter with her homework, then I WILL be loosing the will to live !
Cheers Pete
As the adhesive cures it will shrink a little and this will pull the whole of the tile back towards the wall. At the edges of the tile there are the bases of the clips behind the tile and so the adhesive set bed thickness can't be less than the thickness of the clip base, whereas in the centre of the tiles the bed thickness can shrink back to less than the thickness of the clip bases and cause the bowing in the tiles.
Just a guess at a possible cause!
I see what you mean, maybe the slimmer Rubi clips will make a difference ? Hats off to you people who do this everyday.
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
