Discuss Tiles falling off 12mm ply.... in the Canada Tile Advice area at TilersForums.com.
Diamond Pool Finishers
Well i'am with Dean on this one, just can't see the point of using any form of wood/plasterboard and there are even more specialist plasterboards out there for this if you want to go looking for them, as he says you still have to tape and tank joints for a 100% job ( i suppose its the fact that dry -gypsum's worst enemy is moister /water the makes me think like this ) but why go there when you don't have to ? sorry
Aston
people always assume that if plasterboard is tanked then the problems solved but mould can form on the back of the board due to variations in room temp, condensation from the pipes etc and that can affect its integrity..
its easy to think nah, that wont happen but it does and we are moving forwards in technology and building methods so i'd go for a suitable tile backer board ie wedi / marmox/ dukka / kerdi board in a water sensitive area.
if i was forced into using a plasterboard, then i'd use a foil backed board, mechanically fixed and then tanked using a similar system to what colour rob has mentioned..
widler
1,328
England
So plasterboard which has been used for decades and everybody who has used it and tiled it with no problems at all have been wrong ?
Sorry i disagree really, yes its junk if it gets wet, but why would it get wet if tiled right?
I knocked one off the other month, not a damp spot in sight!
No mould, been tiled since the 80s, is this just a fluke ?
The D
If you think it is ok then you do it and you can give the advice you think is right and I will give the advice I think is right but pleas do not try and tell me that there have been no problems with plasterboard in wet areas we both know that is not the truth
SJPurdy
tanking plasterboard is good at preventing water damage from water that finds its way through the grout but behind the plasterboard there will be pipes with joints made by plumbers and when these leak the tanking will not prevent the plasterboard being soaked from the back- the plaster board will fail and so then will the tiling and the conclusion will be it is the tilers fault. If however a water unaffected tile backer board is used and the joints sealed then the leak from the pipe will not affect the tiling and if discovered the leak will be blamed on the plumber not the tiler.
The plasterboard may be the cheapest option but add to its cost that of a tanking kit and the time to apply the tanking then it will not be that much cheaper (especialy if you get a leak behind it).
Colour Republic
No one coming in with the big benefits to using plasterboard in wet areas?? no surprise there
Hang on Deano! I haven't abandoned this thread just mearly gone out for dinner, now i'm back I might have had a few so i'll reply in the morning but safe to say i'm not disagreeing with what your preference is in the slightest, just saying what I would do in the OP's situation, to me it's all good debate not who's right or wrong ;)
catch you tomorrow
m3fitter
Reply to Tiles falling off 12mm ply.... in the Canada Tile Advice area at TilersForums.com
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
