tiling a bath panel
Hi Bruce lee :welcome:
Topps Tiles sell backerboard , thats were i get mine from , i assume there is a store near you ?
If you've got a CTD near you, they sell Wedi which is my favourite for forming bath panels :thumbsup:.
Broken Link Removed
Broken Link Removed
4x the price of hardibacker and wont do the job aswell,Will need to be braced and well fixed otherwise will move and flex
I've not experienced anywhere near that difference in price. I agree that the frame requires sufficient batons, but when you have formed an access panel it doesn't take much more effort to add a couple more batons to eliminate flex.
Hardi, Wedi, Kerdi or any other tile backer board will be better than ply as long as the frame is structured well.
Hardibacker £7.50 a sheet+vat, 2 required
Wedi bathboard £55+vat for 1800x800
Foam board or cement board?No brainer really
Used to be a big fan of Wedi but the price is too high and there are far superior products out there
Sorry, but I have to disagree.
Hardi is £7.50+vat but that is for the 6mm boards, not the 12mm. The 6mm boards are no good for panels only for overboarding a floor.
You can get 10mm Wedi (BA10 - 2500 x 600) approx £23+vat from CTD.
I agree it will be slightly more expensive than the Hardi but not vastly different.
The Wedi is cement lined fibreboard, so pretty strong too.
Captain, how do you go about forming the panel support? I have my way but always looking for alternative/easier methods.
I make a frame including vertical supports with 2x2 which I screw to wall and floor. I generally use 500 hardi (hadn't thought about Wedi but would be much lighter and easier to cut...). For access I usually cut a gap maybe 20-30mm smaller than a tile in the bottom row and just use silicon to hold the tile in place. plusses and minuses with any access as it's virtually impossible to do it invisibly.
bath panels can be created loads of ways....
wedi,hardi,ply, plasterboard (tanked), this one was created with ply over 2x2 carcuss:
note the 4 little screw caps.....other ways can make them invisible!...unless brickbond....then you are stuffed!
Broken Link Removed
Can't open that mate................:mad2:
