Sukie666
Hi, I desperately need some advice. Six months ago we did up our kitchen diner. With a modern kitchen and two young children we decided to go for large format porcelain tiles and a wet underfloor heating system. Two months ago, a number of the tiles started to lift. Having been on the ebuild forum I understand it was due to the poor prep work on the subfloor. For an area of 36sqm, using 60x60cm porcelain tiles with UFH my builders should have added struts before putting the 18mm ply wood. The ply was screwed down every 9 inches instead of 6. They used a pva primer and to top it, used a dot and dab method with the flexible adhesive.
I managed to get the builders back in after endless calls. They took up one row of tiles which came up with ease. I made them screw the ply down every 4-5inches and used the recommended BAL primer and single part flexi adhesive. These seem to be okay at the moment but how long before they go again? The rest of the kitchen is all coming apart now and will need to be dealt with.
Question is, do I cut my loses and just go for wood or try to stablise the floor and retile? *I've been told that the only way to guarantee against failure is to strengthen the floor with struts. However, having spent nearly £4k on the Ufh I am reluctant to throw all that away and spend another 4-5k on it's replacement *after the supports have been added. Plus, with the new kitchen, it would be extremely difficult to get to pipes etc.
Is there another way? Would screwing down the ply more and using the BAL products be enough? Can Ditra matting or movement joints be use to help?
Any help/advice would be most appreciated.
