Tiling to gypsum based substrates/backgrounds.
valid points being made [MENTION=43777]DavidHoweTiling[/MENTION]
I dont know a fixer that comes in here that uses Anhyfix on walls......
and i agree about the forum......i just wished everyone of the tilers that come in here would read some of the posts......
everyday is a school day.
If anhyfix came in a slow set, I probably would use it on skimmed walls, however, it wouldn't be much use in wet areas so if I were doing a shower room I'd need 2 different adhesive types for the walls, and that's just a pain!
on my post on the other thread I ment to say gypsum based substrate floors so dave I never ment to bring in walls as theres no problem with them. as you all should know there is a very vast difference between floor based gypsum and walls that's why so many people are having failures on the floor not using appropriate adhesives and techniques and they need to know how to prevent this happening in the future. and the best way to do that is by using like for like on the floors
I've heard of floors failing with gypsum based adhesives because the prep work hasn't been done right and that's what it always boils down to. If you know how to prep the floor correctly then you should never have a problem
You have to have a little chuckle at widler ...lol lol..
My point isn't about what should and shouldn't be used , it's if you tile to any gypsum based background , should you be using fypsum adhesive or is it one for floors and anything for walls lol..
Ray ! .. You still haven't answered my question ?
thanks for chipping in Alan , I and many many others know your views and yes we know all about switching to gypsum adhesives for anhydrite screeds , I'm asking , should they be using it on skimmed walls as well , after all in the words of another member , if you use cement based adhesives on gypsum backgrounds , you are ALWAYS got to get a reaction.
That's what I come on for dave, a chuckle , you gotta laugh mate [emoji23][emoji23]
i have always used cement based but so far all screeds have been heated , I have one to do very soon and its unheated
, so I'm going to use Anhyfix as it allows that extra % of moisture in the screed , just incase lol...
walls ? , well as usual I use cement based..
you've never used anhyfix dave that supprises me. you will be in for an education .
All the the floors I have done Ray are for the same builder and he refuses to change from a method we have used and works before these gypsum adhesives came about .
the floor I am using Anhyfix on is one of my own , hence giving it a go.
So did you never use cement based on an anhydrite then Ray ? , you still haven't said. 🙂
No need usually for gypsum adhesives on skimmed walls as long as they are primed. There's not enough moisture borne sulphate ions to promote an adverse ettringite reaction. It's all about balances and checks and molarity etc. in short you are unlikely to get much ettringite on a skimmed wall.
That was my next point when someone said they had used it on walls as it isn't suitable for wet areas , bahhhh you've spoilt it now :lol:
I'm curious as to why if anhydrite screeds are the bees knees and gypsum/anhydrite-based adhesives are the way forward, why don't BAL or Mapei make one?
dave how can you comment on these adhesives when as you say you've never used them??
and im well aware of what can be used in wet areas about 4yrs ago did 45 wet rooms for a builder on a site in Richmond
and no I use tilemaster products on walls as theres a vast difference between gypsum walls and anhydrite(calsium sulphate) floors as ajax123 asjust stated
Dave,
Dave,
Dave,
Dave,
