Guest viewing is limited
Discuss To back-skim or not to back-skim? in the British & UK Tiling Forum area at TilersForums.com.
bugs183
in theory you'd back butter all tiles, ceramics can absorb any moisture quickly and therefore could debond, and porcelain doesn't absorb anything and could debond too because you are totally relying on the polymers in the adhesive to stick to the tile, bit of a weird one when you think look at it.
I tend to back butter all porcelain, big, small, walls and floors, just to be on the safe side. As for ceramics, i don't back butter walls as a rule, but it is a good idea to back butter floors and wet areas, as there is a mechanical key to the tile when buttering, and it means you have fresh adhesive touching adhesive when the tile is fixed to the floor.
It doesn't take to long to do, and a belt and braces approach is better than going back to sort problems
Reply to To back-skim or not to back-skim? in the British & UK Tiling Forum area at TilersForums.com
    • Winner
As the title suggests, Schluter have just unveiled their new advanced wet room course at their...
9K
GoneGuy
Some info you pro tilers might find useful... TTA urges extra care on tiling with mesh-backed...
Flintstone
F
Although I've been a member for a little while I have just started reading through different...
5K
StevieBoy
Hi all, I've had to come to the arms now to get a definitive solution to a problem I'm having...
2 3
MW Smith Ceramics
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
