blades for the grinder that cut faster so as not to spend so much time using it.
Tried a new Bosch blade from @Pro Tiler Tools this last couple of weeks.
And it's very rapid, cuts thin tile as fast as I can walk with it. Ok so it's not for finish cuts, well it doesn't seem to be at the moment.
Possibly still bedding in, although the concept of that I find irritating, but for hidden cuts around a floor and the like it's proving to be excellent.
If you don't hold your grinder true and straight tho, it will literally tear through.
Bosch Dry & Clean Cut Diamond Angle Grinder Blade 115mm 2608615076 | Buy Bosch Diamond Blades Online from Pro Tiler Tools - https://www.protilertools.co.uk/bosch-diamond-blades/52435/bosch-dry-clean-cut-diamond-angle-grinder-blade-115mm-2608615076
I must admit tho, I'm always dubious about recommending blades, we all have different requirements and expectations, so it makes it a difficult task.
I don't use a laser either Andy. Take sigma cutters for example, I was due a new cutter as my rubi 600 was basically worn out, now I couldn't ever use a rubi again.
Laser level is probably one of best pieces of kit I have ever purchased . The amount of time it saves when setting out bathroom walls is loads . Also when pricing up floor work it is very easy to see how much the floor drops so you can calculate how much levelling comp you need . Also on some floors very easy to put in set screws prior to levelling to get a very flat floor . The more you have one the more uses you will find to improve your working practises.
What laser level do you use then for that?
Stanley cll don't know if they are still available now . Their was a time that when I was getting the laser out on a job that other trades and tilers I was working just went out and purchased one .
