Discuss Transit Nightmare in the Canada Tile Advice area at TilersForums.com.
AMtek
Having an absolute mare with my van. Driving home and gearbox is stuck in 4th so i limped back and parked up. Did a bit of digging round google and it seems that it might not be too much of a job to fix so i go back out and try to open the bonet but the bonnet release won't work (key through the grill into a lock, turn one way turn the other and should release). tried WD40, a good bit of force behind it, tried spare key but it just won't budge! so anyone got any ideas now? could drill the lock and just cable tie the bonnet back down but i have no idea how to drill the lock?
dave l and l
i had problem with transit lock on 04 plate
ended up drilling lock out. took a bit of time bit it got me in to engine. seems common. i ended up using a screw driver to release the bonnet.
just be careful when boring lock out try to do a bit at a time.the best thing to do is get a look at someone elses lock then go from there
charlie1
Once you get in to the bonnet, have a look at the gear selector on the right hand side of block, there are 2 cables going in, these will need disconnected (they clip back in easily) you can attempt to take the whole thing off (6 bolts) but may not be necessary. Simply spray the whole mechanism with lithium grease and gently try and get some movement back in to it, happened regularly on my 52 plate!
AMtek
it almost feels like it will go in and out of 4th but thats it, gear stick seems to move about quite freely but can't find any gears, won't even go into neutral. there's no whining from the gearbox, there was no bang, nothing. I know it isn't the clutch because i used 4th to get home and clutch was working fine, was stinking by the time i got home though!
Reply to Transit Nightmare in the Canada Tile Advice area at TilersForums.com
Hi all Interested in views from the trade world about how I should deal with a big floor tiling...
2 3 4 5 6 7 8 9
41K
So I've had my 1200 for a while now and it's done 5-600 cuts, mainly travertine, 610 x 405 x...
25K
Jelthetiler
How to drill a hole in a steel bath. At 365Drills we provide either the equipment you need or...
6K
Deleted member 1779
I am in no doubt that our friend Wivers is now flying high! Before a company goes public...
wivers
Hi all - greeting from Sweden. I'm working on a project right now - rebuilding my "uteroom" -...
Uheat - Keith
U
Transit Nightmare
    Votes: 13 8.8%
    Votes: 11 7.5%
    Votes: 44 29.9%
    Votes: 17 11.6%
    Votes: 35 23.8%
    Votes: 20 13.6%
    Votes: 15 10.2%
    Votes: 7 4.8%
