The Legend; Phil Hobson RIP
Again it's all been said,
All,
Thanks for all the quick replies, great stuff!
I no particular order...
My local tile warehouse recommended sx-1 for first screed, then also over wires. He now says he didnt, so somewhere there has been some confusion. Never the less, i just need to get some confidence its either no problem at all, or its definately something to worry about.
Yes, I used a knotched trowel / comb with flexible adheisive on insulation boards. They seem to have stuck well no problem.
I think the hollow sound is because of the boards, and not a full solid base like concrete for example. It just 'sounds' a bit fragile, maybe i am worrying too much. Just wondered if anyone recognises what i'm explaining when screeding over boards.
The screed seems to have bonded to the boards ok, and as Dave says I think the hammer test(!) is becuase its a shock point load crushing the foam, allowing screed to break.
No heating under appliances or kitchen units, just open area.
As built in I could set appliances, dishwasher and washing machine, on a wooden base to spread their load under the cabinets.
If latex Plan is a close match, no fibres, and seems ok then maybe sx-1 is too.
Tremco technical support have told me that all their screeds meet the BS of 27deg surface temp, but would normally recommed the sx-100. They havnt tested any of them it seems, just developed them to meet certain properties, if they can do this without testing.
Just an update on the floor screed. I have had the UFH on and off since yesterday. The floor now has shown hairline cracks all over it, seem to be in lines where joints of the insulation boards are below, but some run do run diagonally. They seem to have got a touch worse after cooling, though that could just be me seeing more of them the more i look! It does also seem to be de-laminating it from the insulation in places too.
I looked at the ditra product, it looks great. I spoke to them, but they advised it was only as good as the surface it was laid onto, makes sense.
So, i think i'm going to make the decision and have a busy weekend taking the screed and UFH wires back up.
I have tried a patch, it seems to come up and leave insulation surface resonably intact. What are the views on keeping the insulation down and re-laying wires and correct(!) screed over the top? Obviously all primed propoerly?
Thanks for any more advice.
