*UPDATED* Wet Room Project Build Thread!
Will get the pictures rehosted this weekend, not sure where they went?!
Any problems, gis a shout Adam.
Looking at original post, it doesn’t appear as if youve actually downloaded them in to the post.
Once you download them in to the post, don’t forget to actually select
‘insert every image as a thumbnail’
See image below.
It appears you’re not actually uploading the images Adam.
I would normally be able to edit your images, but the image doesn’t appear to be in the original post.
You have to upload image and then select either
‘Insert every image as a’ then select thumbnail.
Or if it’s just a single image,
Select insert thumbnail.
Tanking and Wetrooms
Adam18Spring,
Lou,
Adam18Spring,
Lou,
