Stu78
Hello everyone, I'm newly joined but have searched this forum many times before and always found it helpful and (hopefully) friendly!
I'm hoping for a bit of advice about my front path, I should say up front that i'm not a pro tiler just a DIYer but I'm worried I may have bitten off more than I can chew with this job...
I live in a normal victorian terrace in South London, and originally there were the 6" square (1"thick) black and red quarry tiles on the path out the front in a diagonal diamond pattern. There was no sub base to speak of, and quite a few were cracked, wobbly, big weeds growing through etc. I pulled the lot up (they didn't offer much resistance) and cleaned them up ready to re-lay. I also sourced a few replacements having measured up and worked out exactly how many wholes and halfs of each colour I needed.
Next, I dug out the path and laid a concrete slab (good n thick as there was no way I ever wanted to do it again...). Next up after the slab had gone off (this was back in the summer) I laid two lines of paving bricks, one on each side of the path, being careful to keep them spaced correctly and with a slight fall from the house to the pavement.
And thats as far as I've got...
I guess before I carry on I wanted to check whether the above sounds OK, or if I've it up! If I'm good to carry on, what should I be laying them on? I was going to just use use a 3 to1 mix, and I've allowed for a 25mm bed. I've read about other presumably pre mixed adhesives so didnt know if I should be using these instead?
Do I lay the mix down the whole path, or just a few rows at a time as I go? Any tips on how to end up with the whole path being level greatly appreciated. This is probably my biggest worry.
Finally, what about grouting? What to use, and do I do it at the end, or as I go along?
Thanks in advance,
Stu.
Thanks in advance,
Stu.
