des511
Now I am scared:36:
Wasn't meaning to scare you Des. Weight limits are specified for a reason. Me, as a professional tiler, would not do for a customer what you are looking to do for yourself. It would have serious reprocussions for me insurance wise if anything went wrong.Now I am scared:36:
BAL white star is suitable for fixing natural stone and there is nothing wrong with dispersion adhesives.White star was the only tubbed stuff I used. As for the question by the original poster, I wouldn't use it on stone, therefore my responses were in relation to using bagged stuff. The general concensus on the forums by much more experienced tilers than me is that you will only get 4 to 5m2 out of a 20kg bag of powder.
As the poster was questioning the max weight of skimmed plasterboard and was wanting to fix travertine, I quite rightly stated that with the adhesive and grout, he would be exceeding the maximum safe limits for that substrate and he needs to think again.
You obviously have a different opinion and that is fine. However, even with your own figures, 3kg of white star per m2 plus his 18kg for tiles still exceeds the safe limits for skimmed plasterboard, not allowing for the additional weight of the grout. If he decides to follow your advice that is his choice but personally if it was my children sat in the bath with the possibility of 25 or 30kgs of tile falling on them because I had ignored valid, correct advice I would be mortified.
You are absolutely right, White Star will fix natural stone and there is nothing wrong with dispersion adhesives.BAL white star is suitable for fixing natural stone and there is nothing wrong with dispersion adhesives.
If the tiles are only 18 kg there is no problem
Why is that then? I am not trying to be argumentative, I am just trying to understand why you think there is not a problem?If the tiles are only 18 kg there is no problem
No problems Des. Good luck which every way you decide to go. Maybe drop us a couple of pics when it's done eh.The 3 walls that I am Iooking to tile regarding dimensions are
Wall 1 1.8M x 2.1M
Wall 2 1.6M x 2.1M
Wall 2 0.8M x 2.1M
but as you say the problem is not the size of the wall but the strenght of the skim on the plasterboard. The weird thing is that if I would not have come across this forum I would have never thought about the weight issue and would without a second thought put the tiles on the walls.
It makes you think that how many people have done it.
Looks like I will have a busy weekend ahead of me as I have to make up my mind by Monday about what to use.
Thanks again.
