What order - Tile Colour Intensifier / Protector?
I'm not having much luck in getting a straight answer out of Topps Tiles so wonder if someone on here could once and for all give definitive answer in what order tiles should be treated..
Bathroom wall tiles, unpolished travertine white mosaic from Topps tiles. Originally told to grout, then treat with Fila first wash to clean and finally use Fila unpolished travertine tile protector. All good.
Different chap in Topps then said I should also use Fila colour intensifier after cleaning with first wash and before applying the unpolished tile protector? They then had a large debate with one saying the colour intensifier is also a protector and you don't need the protector after using it!?!
Can someone please clarify exact order of applying. I've never used unpolished travertine before so keen to get it right! I'm not even sure if I need the colour intensifier as it's a fairly pale straightforward whitish grey tile.
Many thanks in advance
