Discuss Anhydrite Screed Question in the Tiling on Underfloor Heating area at TilersForums.com.
Just Rizzle
Still have never seen one of those floor...
got 3 to do in next 5 weeks total of 250 mtrs 2 with natural stone and one with 800x800 porceline over 120mtrs will decouple all using ditra and will sand and stick the ditra down with tilemaster anyfix I then screed over the ditra then stick the tiles with tilemaster flexi addy .
it is my tried and trusted method that gives my clients the confidence to trust me to lay there floors ,and recommend me to there friends and family, for 75 percent of my work is by word of mouth.
do you check moisture levels ray?
Just Rizzle
that is the first thing I do. i have a sovereign meter and it has a light system red, amber, green. if its not green its a none starter. I test the floors on a regular basis so the client can see well in advance if his floor will be ready for the dates we have booked in all the floors I have got lined up are all green but they were all laid in October last year and have been commissioned and working.
Just Rizzle
Why would you screed over the ditra?
yes.
I skim over with a flexi slc usually tilemasters then fix with a flexi addy after priming the screed
I do this so the ditra dosnt get squashed working on top of it so loosing its strenght
White Room
You saying your customers will wait a year for you to fix there tiles ?
H
hmtiling
yes.
I've seen the voids in ditra\durabase filled in once before tiling on top. I know this isn't recommend by either company and the only reason i can think of is to speed up laying the floor when prep is priced separately. Is that why you do it ray?
Imo it's just another bond that doesn't need to be there, and therefore jeopardises the uncoupler doing it's job properly
Just Rizzle
were did you get a year from?
a deal with a few builders they say there building a house etc and give an estimate time when they want it tiled and I tri to oblige .
seeing a guy next week whose planning to build 9 5/4 beds recons tiling will be required from sept till dec
Just Rizzle
the reason I do it is to stop the ditra from been squashed an damaged kneeling all over the floor as you lay your sqashing the day lights out of it
Reply to Anhydrite Screed Question in the Tiling on Underfloor Heating area at TilersForums.com
Further to my other post re our hollow tiles issue It looks like our tiler has dot and dabbed...
